RM European Auto Parts
Results 1 to 9 of 9
Thread: 86 325e starts but won't keep running
    Jun 2019
    Lexington Tennessee
    1986 325e 1977 280Z
    I'm bringing one back to life after fifteen years. I installed a new fuel pump/filter, old one froze. I've got it starting consistently but it only runs for a second or two. It will start twice then you have to let it rest for a few minutes and it will start twice again. Has anyone else had a similar problem? Thanks for the help!
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    Welcome to the Forum!
    You have a rare bird there as in 86' only the 325e was sold in the U.S. for the 3-series, as they discontinued the 318i until 1990.
    So what other work have you done already?
    I am hoping that you drained the tank and got all of the varnish out when you replaced the fuel pump and filter.
    Next would be to have a look at the ignition system, pull off the cap and inspect it, and the rotor button. Also have a look at the wires, ensure they are not cracked, split, ect.
    Then have a look at the intake system, make sure the MAF moves freely, and the idle stabilizer valve, and throttle body is clean. Have a look at the intake boot, and the hoses attached to it, should be free of cracks, splits, ect.
    Lastly before you get too far into this car, get that timing belt replaced, it is way past due. On a side note, it may have skipped timing already, and that is why it isn't running.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    Jun 2019
    Lexington Tennessee
    1986 325e 1977 280Z
    Fuel system cleaned, good spark, in time because it runs great for a short spell. I'm trying to figure out what the piece in the picture with no cover on it does. It appears to be some kind of vacuum diaphragm. Hoses all appear good. Replaced slave cylinder, it was froze up. It's a really nice clean car!
    Sent from my SM-N960U using Tapatalk
    Jun 2019
    Lexington Tennessee
    1986 325e 1977 280Z
    Fuel system cleaned, good spark, in time because it runs great for a short spell. I'm trying to figure out what the piece in the picture with no cover on it does. It appears to be some kind of vacuum diaphragm. Hoses all appear good. Replaced clutch slave cylinder, it was froze up. It's a really nice clean car!
    dworthy's Avatar
    Nov 2010
    I would have to pull out the book for that one, as it does work with the vacuum system on the car, just cannot remember what.
    Put the timing belt at the top of your list, for if it strips out, the motor will be kaput.
    Also it isn't a bad idea to just do the waterpump at the same time, for it is right there.
    Darin
    Current:
    Past:
    M-Flight Member
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    I owned an ‘85 325e for 15 years. That is an altitude sensor, if memory serves me.
    Yes, the belt and the tensioner pulley need to be replaced ASAP. As Darin has written, your engine is toast if that belt breaks. Replace it (there’s a kit with all the parts), the water pump, the thermostat and the belts.
    Jun 2019
    Lexington Tennessee
    1986 325e 1977 280Z
    Can you tell me easily where the sensor is? I'm at work right now and can't look it up. Thanks!
    Jun 2019
    Lexington Tennessee
    1986 325e 1977 280Z
    Quote Originally Posted by MarcoZandrini View Post
    Found it! That's the part in my pic with no cover. Now to find replacement.
    dworthy's Avatar
    Nov 2010
    Here is a useful website:
    Parts book: https://www.realoem.com/bmw/select-us/select
    Online Dealership: www.thebmwminipartstore.com <- a forum sponsor.
    Online Store: www.rmeuropean.com <- also a forum sponser
    Darin
    Current:
    Past:
    M-Flight Member
  1. Starts but will not keep running after head gasket change
    By karoliens in forum 1983 - 1991 (E30)
    Last Post: 04-29-2014, 02:23 AM
  2. 86 325e Starting issues/ Won't idle/Dies
    By mischief3003 in forum 1983 - 1991 (E30)
    Last Post: 04-21-2010, 08:53 PM
  3. E38 starts but won't stay running (jinxed myself)
    By sdmike1 in forum 1995 - 2001 (E38)
    Last Post: 01-29-2010, 11:19 AM
  4. HELP! 86 325es starting/ignition issue???
    By 86red325es in forum 1983 - 1991 (E30)
    Last Post: 05-11-2009, 06:41 PM
  5. 89 535i starts, but won't stay running.
    By Ramm328 in forum 1988 - 1996 (E34)
    Last Post: 03-20-2008, 02:52 AM
