Recently I dedicated a new (to me) laptop to BMW software duty.
The new INPA install i have is in English, but the codes pull in German. I troubleshoot IT crap all day so I decided to leave it as it is for now.
As a result, I need some help with a few new codes that I wasnt able to find a translation for on the interwebs
Engine codes:
62 Aussetzererkennung, Summenfehler,
188 DM-TL Feinleck (1,0mm)
125 Temperaturfuehler Kuehleraustritt
122 Umgebungstemperatur
+ a zyl (cylinder) 4 and 5 misfire code, easy enough to decipher that one on my own
Transmission code:
49 Symptom Gangueberwachung
Im sure one of the temperature codes was for my missing ambient temp sensor which I have since then replaced.
If you have a Bentley manual you can look up those codes, they are right next to the Pxxxx codes.
Roger that, reminded me that I needed to find a copy.
For future reference to anyone else:
62 Misfire Detected - Fueling Disabled
188 Evaporative Emission System Leak Detected (small leak)
Wasnt able to find the transmission code, nor code 122 or 125. I believe 122 deals with my turn signal needing replacement.
Odd that all the codes arent listed
try this?
http://endtuning.com/bmwcodes.html
