Results 1 to 12 of 12
Thread: What should be next on my car?
    Jul 2018
    St. Paul, MN
    98 & 99 M3, '06 E60M5S3
    Hey folks, there's so much out there, and so many opinions on what the best things are to do with our cars in terms of performance and maintenance. Here's what I have done already, I'm wondering what the next logical (key word here) steps should be? ('99 E36 M3, 32k miles)
    Upgrades thus far: Dinan suspension (Front & rear), Dinan cold air intake, Dinan software (stage II), new bushings all around (including RTAB's), headlights already done, B&B triflow exhaust.
    Considering : UUC front/rear sway bar upgrade, throttle body, M50 manifold
    Should I look at ways to improve handling or ways to improve engine performance?
    Thanks!
    Mar 2006
    Menlo Park, CA
    95 M3 & Legacy Manwagon
    What deficiency in the car are you trying to solve? What do you use the car for?
    the logical next step is to go drive it -- autocross, track days, fun runs, etc. Car might be perfect as is.
    "Fear disturbs your concentration" -Sabine Schmit
    1995 BMW M3/2/5-- S54 + Mk60 DSC, California Smog Legal (Build Thread)
    1998 BMW M3/4/5 Alpine/Modena, Z3 Rack, otherwise stock-- DD without burbles
    2017 Chevy SS, Orange Blast Metallic, 6MT -- DD with burbles
    NeilM is offline Member BMW E36 M3 Expert
    Fort Wayne, IN
    96 M3, 15 Golf R, 18 Q5
    Depends what you want to do with the car. Only 32K miles — wow.
    UUC sway bars are OK, will likely work fine with the Dinan suspension.
    M50 manifold would open up the engine's top end. The TB is unnecessary.
    Neil
    FL
    are slow.
    Quote Originally Posted by M3Gonz View Post
    Thanks!
    How do you drive your car? Do you ever rev past 4k rpm? If so, then an M50 manifold is a great upgrade.
    Throttle body doesn't add much power, it's not worth it. They tend to only add 2-3hp.
    Do you want to reduce body roll? Swaybars. I run a UUC front sway bar on medium, and the stock sway bar in the rear. I feel like it's a great compromise. The stock car is setup for understeer, and a slightly stiffer front bar will induce oversteer, so right now it feels really well balanced.
    32k original miles on an E36 M3, you should consider keeping it stock if you plan on selling it in the future.
    I have a brand new UUC front swaybar still in the box sitting in my office that I don't plan on using. PM me if interested.
    -Dr. Seuss
    Nov 2010
    Whidbey Island, WA
    1998 Techno M3 Coupe
    Tires are possibly the best upgrade you can do for a car. You running great tires? What about cosmetics? What wheels are you running. It is not all about suspension & engine which, it seems, you have already made investments.
    Aug 2013
    1999 BMW M3 Coupe
    Yeah I also vote for tires/wheels. Not only can you decide whether you want to run wider tires for more grip or change from staggered to square for less understeer, but many aftermarket wheel choices will also offer weight savings over stock even in wider sizes (I think my Apexes were 7 or 8 pounds lighter per wheel). Or, you could source a specifically sized set of BMW wheels and run those. There's a lot of ways you could go and it can potentially make a big difference in both looks and performance.
    FL
    are slow.
    Can second the difference lighter rims make. Going from my heavy Contours to Apex ARC-8's felt like the car accelerated way quicker.
    -Dr. Seuss
    Jul 2018
    St. Paul, MN
    Thanks everyone for the ideas so far, I'll look into some lighter rims/tire setups for sure.
    Like a few said, at 32k miles everything I'm doing so far I'm making essentially reversible, and I have a whole rack of the stock parts I've taken off and replaced.
    I'd like to improve the handling for sure. We have a '98 M3 (with a billion miles) that isn't nearly as fast as the '99, but it handles way better between the UUC sway bars on it and the Koni suspension and slightly lower stance.
    Fort Wayne, IN
    I have Michelin PS4S tires on both my M3 track car (transit/wet track) and my Golf R (daily). Awesome grip and surprisingly not harsh.
    Neil
    Oct 2003
    Seattle
    99 M3
    Dinan suspension uses Koni Strut and Shocks, plus proprietary Springs.
    Apr 2006
    Harwood, MD
    95 M3
    Not sexy at all, but have you considered your cooling system? From everything I have read, the plastic parts are ripe for failure if they havent been replaced. For piece of mind, I just replaced my entire system (water pump, fan, fan clutch, belts, thermostat, tstat housing, hoses, radiator, and expansion tank) with upgraded parts from Stuart and Mishimoto. It would have taken a day or two if I didn't goon the torquing of a water pump nut/stud.
    Sent from my SM-G930U using Tapatalk
    Borla exhaust, Conforti CAI/Chip, Power Pulley Kit, B&M SSK, H&R Coil over suspension, X-Brace, Racing Dynamics strut brace, Mishimoto aluminum radiator and expansion tank, 80 degree thermostat and metal t-stat housing, Stewart water pump, E46 M3 seats, Braided stainless steel brake lines, Black Fikse Profil 5s wheels.
    Jun 2014
    northern michigan
    95 M3 - 06 X5 3.0
    500-600 hp turbo setup
    E36 M3 S50 - E53 X5 M54 - 1980 Porsche 931 - 2001 Impreza RS25
  1. Ok, So Next Week My Car is Going Under the Knife for....
    By Darth Maul in forum BMW Rides & Events
    Last Post: 09-28-2006, 04:17 AM
  2. When's the next SoCal German Car Cruise???
    By PourkyM3 in forum California sponsored by Avus Autosport
    Last Post: 05-13-2005, 05:59 PM
  3. Next problem with car running.
    By Joshh in forum 1983 - 1991 (E30)
    Last Post: 04-08-2005, 11:02 PM
  4. Replies: 32
    Last Post: 05-27-2002, 07:26 PM
