Results 1 to 4 of 4
Thread: Brake Fluid Job/Cost?
    Mar 2018
    Georgia
    2014 BWM 535
    I've got this brake fluid light that came on under "Service Required". Based on a couple of quotes, it sounds like this will cost around $150-175. I was just wondering, what does this entail, is it merely filling up some brake fluid or additional things such as a flush or something else?
    Jun 2008
    Dallas, Texas
    '14 550/M, '03 540/M
    Quote Originally Posted by tm1900 View Post
    that appears to be about right $$ and they should use a machine to flush and replace the fluid.
    Correct. It is a total flush of the braking system. Typically done with a pressure or vacuum bleeder.
    Michigan
    2005 325Xi
    Our guys will use a turkey baster to suck out the fluid in the master cylinder, then replace that with fresh fluid. Then put a pressure bleeder on there, and push fresh fluid thru each of the 4 brake lines till it runs clear.
    Quote Originally Posted by B4SH View Post
    If anyone knows, it's this guy who knows literally nothing about everything.
    Quote Originally Posted by fcvapor05 View Post
    Do you even OT? The mean 401k around here is probably about $6, what with all the shiny cars and $1,000 watches and donations to get other members' Volvos running.
  1. Replies: 4
    Last Post: 08-16-2011, 01:58 PM
  2. Brake Fluid Swap Job
    By alphabimmer in forum 1991 - 1999 (E36)
    Last Post: 09-21-2008, 07:53 PM
  3. How much should a good brake job cost?
    By briankern in forum 1991 - 1999 (E36)
    Last Post: 11-01-2006, 06:20 PM
  4. How much does a brake job cost???
    By deadgame in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 09-18-2005, 11:13 PM
  5. Brake Job Cost?
    By Philo in forum 1992 - 1999 M3 (E36)
    Last Post: 10-13-2003, 02:49 AM
