Results 1 to 15 of 15
Thread: Help, crank pulley came off!
    Nov 2016
    texas
    1998 328is
    This is horrible, I was driving down the road and I hear a crunching sound, pull over n My freaking harmonic balancer/crank pulley was loose, it destroyed my belts and my water pump pulley, I took the 8 13mm bolts and removed the crank pulley entirely, what to do now? Is my engine out of time, I know I’m gonna need another belt but the harmonic balancer looks undamaged, what should my next move be, I never would have thought that pulley would have came loose. It’s an m52 so I don’t think I need to worry about the crank sensor.
    98 328is/5 Arctic silver
    99 528i 5speed Alpine white(Totaled Unfortunately)
    Oil pan and timing chain delete, weight reduction right?
    98 540i/6 (New baby)
    Dec 2013
    People's Republic of MD
    22 doors and 4 tops
    Relax.
    Engine cam timing does not rely on the balancer, that is all done internally and since you have a OBD2 engine the crank sensor is in the rear.
    Check your balancer and pulleys for any damage, replace as needed and get new belts. Torque it all correctly and reinstall.
    Jan 2016
    Ca
    2001 525it
    second that
    Feb 2016
    tempe, az
    1998 Z3M, 2006 330i
    The biggest danger is that you have damaged the crankshaft. This happened to me on a Z32. It was obvious by visual inspection that the loosened pulley had eaten up the end of the crankshaft. If I ever take one off again, I'll safety-wire it back on. I had to get another engine. I hope yours is okay.
    May 2017
    Owings, Md
    1998 328i
    Quote Originally Posted by spyderg0d View Post
    I would be most worried as to how it came loose. Isnt the engine supposed to tighten the main bolt by direction of rotation?
    This is negated by the keyway. From what I have heard anecdotally the s52 has a higher probability of this due to crankshaft harmonics. In my first hand experience, the end of the s52/m54b30 crankshaft is ever so slightly smaller than the m52 crankshaft and the damper fits on looser as a result (same damper). I put a m54 damper on my stroker and it was a snugger fit.
    Jun 2010
    NY
    1997 328i
    Inspect the pulleys for any dents or dings, it will be off balance if there are any. You will need two new woodruf keys for the crank and a special wrench to properly torque the crank bolt.
    https://www.ebay.com/itm/BMW-M20-M40...L/143203476386
    2 woodruf keys
    https://www.rmeuropean.com/Products/...MFG9-V260.aspx
    Jan 2002
    outta SoCal, now CO
    '98 M3 Alpine White
    You didn't say if the 6 smaller 8mm pulley bolts came loose or the big 18mm center bolt into the crankshaft came loose.
    See ya later,
    tony
    '98 M3, '92 Dinan3, '05 R1100S BCR, '07 R1200S, Aprilia T
    May 2017
    Owings, Md
    1998 328i
    The only effect of the engine's rotation to tighten that bolt is working against the inertia of the bolt, which is small. When a bolt is threaded in a specific direction to keep it tight (like bicycle pedals) it is so so any motion of the object being secured will be in the direction to tighten the fastener, what I was implying is the woodruff key will prevent the damper from starting to spin. These engine rely a tremendous amount of clamping force of the "Jesus Bolt" to prevent the damper from wobbling rather than having any taper.
    Jan 2002
    outta SoCal, now CO
    '98 M3 Alpine White
    Huh? The key way is on the pully to the crank,not the bolt. The bolt has a slip washer and screws into the crank. Keyway has nothing to do with keeping the bolt tight. The rotation of the engine is supposed to sink the bolt inward with every rev increase and keep it from unwinding outward. The only way for one to come out is to be loose and sudden engine deceleration.
    Crank bolts do not just work themselves loose.
    And ive tightened many with just the 22mm socket i think it is and a torque wrench. No need for special tools.
    Might need to rethink that logic. Consider that the big bolt on the front pulley and the oil pump nut are both spinning in the same direction. The front pulley bolt is right-hand threaded and the oil pump nut is left-hand threaded. One would have the loosening issue with RPM deceleration and the other with RPM acceleration. I think we know which is which.
    I don't think the original issue was with the big bolt, anyway, so it really doesn't matter even if I do drill and safety wire the all the oil pump nuts.
    See ya later,
    tony
    Jan 2002
    outta SoCal, now CO
    '98 M3 Alpine White
    Your logic is faulty and your understanding of simple physics is lacking. If what you profess is true and the 18mm bolt that BMW would like to have replaced and torqued to 410 lb.ft. each time it's removed then that bolt could then be installed finger tight and it would torque itself up to 410. Not gonna happen.
    Jun 2010
    NY
    1997 328i
    That makes sense there is no force acting on the bolt. The key locks the pulley from rotating. The rotating engine does not act on the bolt because that pulley is not able to move. If the pulley could move then the mass of the pulley and crank could act on the bolt. There is no torque applied to the bolt other than what the installer performed on the bolt.
    Jun 2010
    NY
    1997 328i
    Zohaibrose, we need pics!
    May 2017
    Owings, Md
    1998 328i
    The fact that the damper interface with the crankshaft is non-tapered means the clamping force of the crank bolt is the only means that secures the damper. There are several accounts of the damper coming loose on track driven s52 engines, from what I surmise, it is a result of tunes increasing the rev limits and the s52 crank harmonics. The harmonic factor would mean the bolts are vibrating loose and for this reason serious racers is a $1k aftermarket mti damper. On tapered crankshafts, the circumference of the diameter is stretched as it is clamped onto the crankshaft by the bolt. This provides an additional layer of protection from the damper coming loose.
    Nov 2016
    texas
    1998 328is
    no what happen to me is the 6 8mm bolts came loose, prob from being not torqued, the big Jesus bolt is still on there but the crank pulley is not. I will post pics now
    Jun 2010
    NY
    1997 328i
    Quote Originally Posted by zohaibrose View Post
    So, you might want to work on how you word things. The crank pulley is the main pulley not the secondary pulley bolted to it.
  1. Help. Crank pulley loose!
    By Romanian in forum 1991 - 1999 (E36)
    Last Post: 06-25-2010, 10:58 PM
  2. Help w/installing crank pulley
    By rollnbmwdroptop in forum 1992 - 1999 M3 (E36)
    Last Post: 06-05-2006, 08:55 PM
  3. HELP! Crank Pulley
    By Red Herring in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-15-2005, 08:12 AM
  4. Damn Crank Pulley!!!! Please Help...
    By Armo95 in forum 1992 - 1999 M3 (E36)
    Last Post: 12-22-2003, 11:01 PM
  5. URI crank pulley help!! (I'm an idiot)
    By 98technovlt in forum 1992 - 1999 M3 (E36)
    Last Post: 12-13-2003, 03:12 AM
