I'm trying to remove the tonneau motor. I've disconnected the cables and rod and the four nuts holding the device in place. I can't pull the assembly out. I can't move it to clear the top or lower bolts. Can you help?
If you removed the 4 nuts, the assembly will come out. May need to give it a light tab with rubber hammer.
It comea out by pulling the bottom towards the middle of the car.
pull towards the center of the trunk, then down. It's kinda wedged in there. (assuming you already removed the cables, electrics, drive rod)
