Results 1 to 3 of 3
Thread: croak/rattle from left hand side when ignition switched on, before start
    Apr 2019
    St Helens, UK
    2001 325i SE
    E46 325i.
    I thought this was an exhaust problem but it happens before the car even starts up!
    On the first start of the day and before I go home from work, there is a croaky rattle from the left hand side at about the midpoint of the car as soon as I put the ignition to position 2. It persists for a minute or two after starting and then goes away.
    Anybody have any ideas what it could be, now that the exhaust has been ruled out?
    Oct 2007
    Studio City, CA
    2007 328i E92
    When you turn the key on from a cold-start, the fuel pump starts up, which pressurizes the fuel in the lines and in the filter. The fuel filter is underneath the car, on the left side, somewhere in the area next to your transmission and against the frame rail. I would say that the fuel system being pressurized is buzzing something that's loose with your fuel filter or filter cover. This makes sense because the fuel system may be dropping pressure in the lines/filter from sitting awhile and then turning the key on begins the pressurizing function - but only after sitting awhile. Check your fuel filter and cover.
    Apr 2019
    St Helens, UK
    2001 325i SE
    Quote Originally Posted by filmy View Post
    Nice one - I was leaning toward the fuel pump as it's the only thing running before startup!
  1. E38 WTB Left Hand Side Headlight Washer Nozzle
    By driversl in forum BMW Parts Wanted
    Last Post: 09-07-2013, 11:50 AM
  2. Akward noise comming from the left hand side of the car
    By carbid in forum 1999 - 2006 (E46)
    Last Post: 05-10-2010, 08:43 AM
  3. Left hand side brake light non functional
    By danny3363 in forum 1991 - 1999 (E36)
    Last Post: 10-28-2008, 05:18 PM
  4. Annoying Knock / rattle front left hand side
    By UJM3 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 03-31-2008, 05:44 PM
  5. weird gurling noise under left hand side
    By Sparkybmw420 in forum 1991 - 1999 (E36)
    Last Post: 05-25-2005, 07:38 AM
