Page 2 of 2 FirstFirst 12
Results 26 to 29 of 29
Thread: E36 M52 IAT sensor and Coolant temp sensor.
  1. #26
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    With all that was going on, a smoke test of the intake to ensure it is 100% sealed would be in order.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
  2. #27
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Congrats! Glad you got it solved. Definitely have the intake manifold smoke tested. You likely have multiple vacuum leaks.
  3. #28
    Jan 2018
    London
    1997 E36 323i Coupe
    Yeh i think a smoke test is in order. I have done all the other tests i can do myself including a home made smoke machine test with a fog machine and didnt find any leaks. But i understand the proper machine is more likely to find one.
    Only thing is all i hear is vacuum leaks would make it run rich?
    Think i should just add now as itll probably help you understand or figure out whats happening. I have fitting a supercharger to this, the set up is-
    323i
    M50 manifold
    36lb injectors
    Sc14 supercharger running around 6-7psi
    Intercooler so - 2ish psi
    328 exhuast still with cat
    Aem wideband sensor
    Order of the equipment is
    Air filter > maf > icv outlet > throttle body > supercharger > intercooler > m50 manifold.
    I have also got a couole tunes from Fekzen (not sure if you know him) but hes done loads of these set ups. So pretty sure its not the tune.
    Hopefully this shines some more like. Sorry jumping on this as i have a couple clued up people involved who can hopefully help as i am out of ideas now.
  4. #29
    dworthy's Avatar
    Nov 2010
    I don't like out of the box tunes on these cars without a dyno session to determine the proper set-up.
    On a newish car, you can use a stock tune, for most parts are still well within stock parameters. When a motor ages, things get a bit looser, and you will need to have this taken into consideration.
    Darin
    Current:
    Past:
    M-Flight Member
  1. OBD1 E36 question about vanos and coolant temp sensor plugs
    By das borgen in forum 1992 - 1999 M3 (E36)
    Last Post: 08-03-2015, 08:45 AM
  2. E39 528 328 e39 e36 M52 Coolant temp sensor / sender
    By 87325i in forum Engines, Performance Parts & Software
    Last Post: 06-17-2013, 11:36 PM
  3. Replies: 2
    Last Post: 07-28-2011, 03:23 PM
  4. WTB 02 sensor and coolant temp sensor
    By NWe30 in forum Pacific Northwest - US
    Last Post: 04-16-2011, 01:57 PM
  5. m52 OBD2 to OBD1-Coolant Temp Sensor question
    By Dave V in forum Engine Conversions
    Last Post: 09-10-2010, 09:54 AM
