Results 1 to 2 of 2
Thread: Fixing bad VANOS rattle in M52TUB engine
    Jan 2015
    Timaru, New Zealand
    Two Z3 Roadsters
    My 2.0L Z3 with a M52TUB20 engine (same as the M54) and 112,700 miles had the dreaded VANOS rattle really bad. Anti-rattle rings were installed in the VANOS pistons when the seals were changed. This provided an improvement but there was still rattle at idle.
    Today I changed out all major VANOS spline parts and the rattle is gone.
    Parts changed were:
    • 11361744263 Sprocket inlet
    • 11361438306 Tooth sleeve exhaust
    • 11361715027 Double spline cup, 2 of
    Do not attempt to replace or alter the spline on the end of the cam shafts. You’ll totally loose your timing with no way back if you do.
    You need the double VANOS timing tools to do this job as you upset the timing when changing the parts.
    The difficulty of the job is the same as replacing the VANOS seals, so if you are tool handy, you should be able to do the job. The hardest part was getting the plastic bung out of the crank lock hole and fitting the crank lock pin. I did this with the Intake manifold in place (right hand drive car) by reaching up from the bottom and feeling my way around.
    Very pleased with the results.
    1999 2.8L Z3 Roadster,
    2000 3.0L Z3 Roadster,
    May 2019
    Uniontown, PA
    1999 Z3 2.3
    Quote Originally Posted by Muzz258 View Post
    Parts changed were:
    You need the double VANOS timing tools to do this job as you upset the timing when changing the parts. Timing instructions are in TIS and are easy to follow.
    Yeah man, im doing some work on my vanos, had a rattle as well, decided on an anti-rattle kit, new seals, and a new timing chain tensioner spring, got my new spring, compared the two, and the old spring was a good 1/8 inch shorter, which I believe is where my rattle was, real easy to swap out, well worth the few bucks it cost.
  1. My engine sounds like an Iveco Diesel truck: VANOS rattle?
    By rocketwagon in forum 1996 - 2003 (E39)
    Last Post: 07-30-2016, 02:36 PM
  2. VANOS Rattle Noise After Engine Start
    By shogun in forum 1991 - 1999 (E36)
    Last Post: 02-19-2015, 07:19 AM
  3. Vanos sounds bad on my new S52 engine. Could it be the solenoid?
    By yellow360f in forum 1992 - 1999 M3 (E36)
    Last Post: 03-11-2009, 02:36 PM
  4. Interesting fix for vanos rattle
    By spaghettininja in forum 1996 - 2003 (E39)
    Last Post: 01-27-2008, 01:42 AM
  5. VANOS rattle fixed
    By KrazyRushin in forum 1992 - 1999 M3 (E36)
    Last Post: 05-07-2005, 07:31 PM
