Results 1 to 4 of 4
Thread: Very specific conditions SRS light coming on
    May 2019
    Phoenix, AZ
    94 740iL
    As the title states I'm getting an SRS light daily. My round trip to work has the same distance, same stop point coming and going, same relative drive speed and same amount of traffic either way. The only variable between coming and going is outside temp. I'm in Arizona so my drive to work now is upper 80s to low 90s. My drive home is no less than 105 degrees. I only get the SRS light on my drive home
    So after searching as many threads as I could I did not find anyone who experienced an intermittent light issue that was similar to my situation.
    I have checked the orange sensors on the top edges of both fender wells. No black goo, no signs of immediate damage.
    I'm guessing since the outside temp is the only changing variable that is the culprit. Heat possibly causing expansion and I'm losing a connection somewhere maybe? Has anyone else experienced this issue maybe even in the opposite aspect of it being too cold?
    Any help would be appreciated as I really dont want an unwanted airbag deployment on my drive home.
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Maybe you try contact cleaner/enhancer on all plug connections, also on the control module.
    May 2019
    Phoenix, AZ
    94 740iL
    Quote Originally Posted by shogun View Post
    Thanks for the response Shogun. Just waiting on my Bentley to show up so I can find all the pieces associated with the SRS so I can go thru and do just that.
    Jan 2005
    Japan
    it is online in the ETM under component location chart and drawings under component location views http://shark.armchair.mb.ca/~dave/BMW/e32/
  1. Replaced passenger seat, now SRS light comes on...???
    By pdx e34 in forum 1988 - 1996 (E34)
    Last Post: 07-03-2010, 06:54 AM
  2. I Think I did something dumb to cause my SRS light to come on
    By suburbanent in forum 1988 - 1996 (E34)
    Last Post: 04-16-2007, 08:46 PM
  3. SRS light come up..lock spring
    By 323iptg in forum 1991 - 1999 (E36)
    Last Post: 01-25-2007, 10:56 PM
  4. Replies: 2
    Last Post: 04-04-2004, 11:17 PM
  5. Peake Research R5/SRS Tool Coming Very Soon
    By bimmerzone in forum Group Purchases & Supporting Vendor Specials presented by eBay
    Last Post: 10-06-2003, 07:44 PM
