Results 1 to 10 of 10
Thread: M30 engine rebuild bearing wear
    Buffalo, NY
    02 540, 89 535, 06 x3
    Tearing down spare m30 for rebuild. Plan to replace rod bearings and possibly swap in forged pistons. I’d like to reuse mains but the wear seems iffy. Was planning to use plastigauge and reuse if clearance is ok. Anyone have expertise here? Also what do you think wear is a result of? My guess was dirty oil.
    NW suburban Chicago
    hiss by my window
    "Iffy"?
    Turn in your tools, man.
    Buffalo, NY
    “Iffy” is a very technical term for...ehhh I could spend the money but damn this is will add up quick.
    Point taken sir. I know I “should” replace them, just needed that extra push. I see Ireland engineering indicates there can be variances in crank size on m30, does m30b35 in e34 deviate from standard?
    Any brand should stay away from?
    NW suburban Chicago
    hiss by my window
    Quote Originally Posted by johnnylud3 View Post
    Re-using those bearings is a fool's errand and false economy.
    Forged pistons imply that you may have some heavy duty use in mind. If you just want to assemble a cheap "grenade" motor to thrash to death then screw it back together as is and wait for the inevitable.
    You said rebuilding. "Rebuilding" implies, no clearly states, that everything has been restored to new specification. Anything less is simply repaired as needed. And yes, it does add up quickly, especially after a trip to the machinist.
    Crank should be inspected and probably at least polished. Hopefully clearances will remain within tolerance for std. bearings and it won't need grinding. Same goes for the rods and re-bush the small ends.
    Any reputable bearing brand is fine, I believe Kolbenschmidt is OE but doesn't need to be German. Don't order them until you know the finished size of the crank journals.
    Glad you got the message so suck it up buttercup, engine building is expensive.
    Good luck with whatever you decide.
    Buffalo, NY
    Anyone happen to have the specs for wear tolerances on bottom end of this engine? Seems to be void in the Bentley.
    Jul 2010
    Vallejo, CA
    '95 540iA
    Do these help?
    Quote Originally Posted by 1990525i View Post
    the bees knees
    Buffalo, NY
    Yesshhh yesshhh! Do you happen to have anything for cylinders? Also, seems there are 3 possible cranks used in m30b35 with varying main bearing size. When I pull up main bearings at parts suppliers websites, there is only one option for standard sized bearings. Did e34 535i only have one of these 3 cranks (red, yellow, green)?
    Jul 2010
    Vallejo, CA
    '95 540iA
    Here. Not sure how to interpret 1) and 2).
    From a file in my car documents called "E34 Tolerances".
    the bees knees
    NW suburban Chicago
    hiss by my window
    I believe there is only one crank journal size, the three different "colors" are to optimize clearances, compensating for minor (very) differences due to mnfg. tolerances. The entire range is only .0007"
    I skilled machinist can examine and measure your crank and tell you if it needs simple polishing(and hopefully remain in the "standard" range) or will need grinding in which case the crank is ground to suit the available bearings.
    Jun 2012
    New Mexico
    2003 328i
    Those bearings look pretty average for being used with I'm guessing well over 100k on them. Not bad at all. They could go for another 100k but while you're in there, might as well do them.
    I'm sure the engine wasn't knocking looking at the pics and was factory original before you took it apart so I would order new, standard size shells and button it up. I would do nothing to the crank journals. No spun bearings, no problem.
  1. 1988 e32 m30 engine rebuild
    By E32 fan in forum 1988 - 1994 (E32)
    Last Post: 03-16-2010, 12:48 AM
  2. Help! 325i engine rebuild (research)
    By chunkyd in forum 1991 - 1999 (E36)
    Last Post: 03-19-2003, 07:45 PM
  3. Engine Rebuild
    By dcardenas in forum 1991 - 1999 (E36)
    Last Post: 08-27-2002, 10:07 AM
  4. engine rebuild vs. engine swap...please help
    By brian325i in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 06-11-2002, 07:06 PM
  5. How much should 1 pay for an engine rebuild parts&labor?
    By Sacramento M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 05-27-2002, 01:19 PM
