Results 1 to 12 of 12
Thread: A/C fan control switch
    birmingham,al
    2001 3.0 Z-3 RD'STER
    It's always something. When I turned the fan control switch on nothing happens. However when I turn it onto the highest speed, it works. After several attempts, same issue. I assume the switch needs replacing. Can I gain access to the switch on the HVAC unit through the radio opening?? Please advise.
    Feb 2019
    PA
    2001 BMW Z3
    Its most likely your fan resistor. Unfortunately, it's located on the blower motor hosing under the windshield cowl. The contacts may need to be cleaned or the resistor needs to be replaced.
    Oct 2012
    Louisville, KY
    1997 BMW Z3 1.9L 5MT
    The low speeds use the resistor and the high speed bypasses it.
    Resistor-changing DIYs:
    https://www.bimmerforums.com/forum/s...on-4-write-up-)
    https://www.bmwcca.org/roundel/hey-k...ed-resistor-z3
    BMW MOA 696, BMW CCA 1405
    birmingham,al
    You are correct Delvec. Thanks
    birmingham,al
    Vintage you have done it again...posted threads that are extremely helpful. Rob's thread is amazing...details w/photos. I wonder how much the BMW dealer would have charged for this DIY. Thanks much, man!
    Oct 2012
    Louisville, KY
    Quote Originally Posted by MORRIE View Post
    ... I wonder how much the BMW dealer would have charged...
    And what if he had first gone for the switch in the console LOL.
    Kent, Ohio
    1998 M Roadster
    This might explain your odd intermittent AC issue--if the resistor is failing and you drive around with the AC on and the fan in positions 1 through 3, the evaporator will eventually ice up, and, when the fan does blow, only warm air will come out; once the evap defrosts, cold air will blow again. (Ok, I think I pulled that off in one sentence for punctuation geeks out there).
    Oct 2012
    Louisville, KY
    Quote Originally Posted by ZedsDead87 View Post
    ... if you had a leak you would NOT go from cold air to hot back to cold... .
    Quote Originally Posted by Mr Bingley View Post
    This might explain your odd intermittent AC issue--if the resistor is failing and you drive around with the AC on and the fan in positions 1 through 3, the evaporator will eventually ice up, and, when the fan does blow, only warm air will come out; once the evap defrosts, cold air will blow again...
    Neat cross-thread deduction!
    birmingham,al
    Here is the little culprit that caused the blower not to work properly. Received its replacement last week. I had to order a wiper arm puller to remove the wiper arms to gain access to the blower where the resister pack is housed. Now the blower works on all speeds. Just another BMW Z3 learning experience. I wonder what's next???
    Sent from my SM-G920V using Tapatalk
    birmingham,al
    Quote Originally Posted by Vintage42 View Post
    Excellent deduction Ralph.
    SW Florida
    99-01 M Cpe & Rdts, X5M
    The takeaway here being that you probably won't have to wait long to find out...
    Kent, Ohio
    1998 M Roadster
    Deduction shmedudtion--how about that punctuation.
  1. E34 AC fan speed control switch knob NEEDED
    By 4re308 in forum 1988 - 1996 (E34)
    Last Post: 05-07-2012, 04:25 PM
  2. Is there such thing as a voltage-controled switch?
    By Keda in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 12-18-2004, 10:16 PM
  3. HELP! With heater control switch
    By Boost Infection in forum 1991 - 1999 (E36)
    Last Post: 12-16-2004, 03:58 PM
  4. Aux. Fan / Temp Switch
    By G.J. Dixon in forum 1975 - 1983 (E21)
    Last Post: 06-08-2003, 07:29 PM
  5. Manual Fan clutch switch addition
    By fstbmwm3 in forum 1992 - 1999 M3 (E36)
    Last Post: 01-24-2002, 05:40 PM
