Hello
I wanted some suggestions or link to make a video input to the car and to install the reverse camera. I had e39 before and i did it but now i am not able to find any diagram or manual how to do it in my e65
I would like to know as well or aux input thanks
What TV do you have in there at the moment?
I had the old analog TV that no longer recieves anything, so adapted it. You could probably do it if you had such a TV.
Something along the lines of:
1) buy a converter from whatever your camera outputs (i assume composite analog) to RF Modulator.
2) Wire the above in and connect the output to the tv signal input of the tv module.
3) Install the camera as normal and connect its input to the TV modulator.
4) Tune the TV and you should get a picture.
You may have to do some googling to get the TV to work while the car is moving. Its an NCSExpert type job, so be careful!
I know of no way to get it to automatically active the TV in the car, so you would have to select it manually.
As for AUX input, it's possible depending on the model you have. But simpler may just be to get a Bluetooth FM transmitter and use that.
[QUOTE=dizze;30300961]What TV do you have in there at the moment?
Analog (CRT) TV? mounted on the dash or wherever? Doesn't sound right,. What am I missing?
Thanks a lot but i have the default tv. the white pin is empty at the box. Is the white pin configuration like the one in e39? I dont have an av option. Where the picture shows? I also mounted aux in module but the aux option is not apearing in the monitor. Thanks
