Results 1 to 3 of 3
Thread: white smoke when accelerating
    Jan 2013
    Raleigh, NC
    1997 540I
    When I press on my gas real hard a puff of white smoke comes from my exhaust. I put Seafoam in my crankcase and drove about 150 miles and changed my oil. I doubt that would be the problem now. I put Seafoam in my other BMW's and did not have this problem.
    It only smokes when I press hard on the gas.
    I did the following repairs.
    Replace all ignition coils and spark plugs
    New valve cover with gasket
    6 New fuel injectors
    4 new oxygen sensors
    new breather hose
    All parts are genuine BMW parts.
    Any ideas?
    Osnabrock, ND
    2004 325xi,2004 545i SMG
    white smoke typically indicates coolant... but not always
    black smoke is usually fuel
    bluish smoke is usually oil.
    does car use coolant?
    now, you said white smoke are you sure its not just steam, when you press hard on accelerator my car will "get rid" of the condensation in the mufflers and such in form of water vapor and steam like vapor.
    Level 1 Certified BMW tech.
    Nov 2019
    Salt Lake City, UT
    '00 Z3, '08 535i
    If you are pressing hard on the gas pedal, it’s most likely the turbos... when they on on their way out they burn oil and gives you the white plumes of smoke only when accelerating hard-ish.
    How many miles does your car have? Turbos need replacing about 100k or so depending on driving style.
  1. White smoke on acceleration
    By mdimillo in forum 1988 - 1996 (E34)
    Last Post: 09-23-2013, 11:56 AM
  2. white smoke when accelerating.
    By angrybird in forum 1 Series & 2 Series (E81, E82, E87, E88, F20, F22, F23, F40, G42)
    Last Post: 07-14-2013, 09:30 AM
  3. Replies: 4
    Last Post: 02-15-2011, 03:54 PM
  4. white smoke/exhaust under heavy acceleration...
    By sjanz in forum 1996 - 2003 (E39)
    Last Post: 02-14-2011, 09:58 PM
  5. White Smoke under heavy acceleration
    By Matt927 in forum 1992 - 1999 M3 (E36)
    Last Post: 05-03-2006, 03:28 PM
