Results 1 to 8 of 8
Thread: BMW E38 M62B44 Strange clinking noise between gearbox and engine
    May 2014
    Slovakia
    BMW e30 2.8
    Hello guys,
    Can someone help me up ? My e38 got strange noises coming from a space between gearbox and engine as video shows: https://youtu.be/iW_9lsvfsjE
    Its horrible when accelerating, it gets louder every RPM - only when moving, but when I am parked in (p) position its just few "clanks" like in video, Gearbox is ok, no problem with it.
    Just curious if someone had same problem as me.
    IL
    2000 740i sport
    Quote Originally Posted by escalade View Post
    Hello guys,
    Could the flywheel be touching the starter?
    May 2014
    Slovakia
    BMW e30 2.8
    good point, hmm
    Apr 2009
    Land O Lakes, FL
    1986 535i, 2012 X5 50i
    My father had a friend that his car made a horrible sound and it turned out to be a cracked flex plate.
    Jimmy Moreno
    BMW CCA 115551
    1986 535i, Arctic Blue
    2012 X5 XDrive 501, Sparkling Bronze Metallic
    May 2014
    Slovakia
    BMW e30 2.8
    i think thats the issue, but, i am not sure
    Feb 2013
    The Motor City
    1997 750 IL
    Sounds like a flywheel to me. I hear that ring all the time on 750 startups. Maybe the starter is not retracting as it should.
    ---- Processing Individual ----
    Z1XX Upholstery
    Seats front and back in Epingle / leather englishgruen,
    As Schl.Nr. B9EG.
    Front seat backrest in Montana Englishgruen (No. 8 174 861)
    Other interior equipment as for Volleder Nappa englischgruen,
    Schl.Nr. P5EG
    Feb 2020
    Florida
    Bmw/MB
    Has anyone ever gotten anywhere with this? I think I’m chasing a similar clink/clank noise once during startup and it also happens a bit more regularly during hard acceleration
    Feb 2020
    Florida
    Bmw/MB
    This was the correct answer in my situation. I had some extra time to work on my car in the shop one day and decided to try to shim the starter. I used two washers on each bolt, it was tricky getting everything installed without the washers falling off of the bolts for the starter. Sure enough my think/clink/ring sound during heavy rpm has disappeared. I still have a bit of a “ping/ring” noise during startup when the starter gear lets go of the flywheel, but this noise does not bother me as much as the metallic noise during heavy engine load
  1. HELP BMW 1997 E36 328i SQUEAL NOISE BETWEEN 700-1300.
    By nickdorais in forum 1991 - 1999 (E36)
    Last Post: 08-07-2016, 10:13 AM
  2. HELP BMW 1997 E36 328i SQUEAL NOISE BETWEEN 700-1300.
    By nickdorais in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 08-04-2016, 06:12 AM
  3. BMW E38 740IL strange problem plz help anyone
    By farhansadiq in forum 1995 - 2001 (E38)
    Last Post: 12-08-2015, 06:00 AM
  4. Strange pulsating noise between 60 and 80km/h
    By ciokan in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 10-22-2014, 05:24 AM
  5. BMW X5 Diesel - Strange rattly noise from engine after shutdown - Major Concern.
    By jangle in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 10-07-2013, 04:29 PM
