Results 1 to 5 of 5
Thread: coolant temp sensor
    Mar 2019
    Denver, CO
    1987 bmw 735i euro
    coolant temp sensor
    Hi,
    I am looking for help for my 1986 735i, 5 speed. I want to replace my coolant temp sensor. The problem I am having, is that the replacement appears to have a piggyback that attaches to the new sensor , with 2 wires coming off of it.
    I think I have the original sensor....it has 2 connectors coming off of it, then there are 2 connections that attach to east post - one connection has 3 wires, the other has 2 wires that are crimped with a connector to each post.
    so my question, has anyone upgraded to the new style, and if so, how do you do the wiring? do you just crimp the 3 wires to one of the new wires on the piggyback, and crimp the 2 wires to teh other wire on the connector?
    the current setup, 1 'post' is wider than the other.
    thanks in advance.
    andrew
    May 2013
    Killingworth, CT
    '84 733i, 01 X5 00 750iL
    Do you have a picture of what you bought?
    Steve H.
    Mar 2019
    Denver, CO
    1987 bmw 735i euro
    This is a picture of what multiple sites are showing as my replacement sensor.....I will try to find a pic of the pigtail that fits in here, but do not have that pic right now....
    May 2013
    Killingworth, CT
    that is the DME (ecu) temp sensor which uses an EV1 pigtail. The 2 spade terminal sensor you pictured I believe is for your dash temp gauge.
    Steve H.
    Mar 2019
    Denver, CO
    1987 bmw 735i euro
    thanks for pointing that out....you are correct. my dash gauge is NOT working - i had rodents in my engine bay several years back, and they chewed the connector off - so I tried the connector shown, and it never worked since then.
    any ideas where to buy a connector (that i can crimp the wires on)? the blue one in the picture was my attempt to fix what the rodents ate, but i'm not sure that worked (either that connector or the sensor itself is bad).
    I also want to replace the 2 spade temp sensor for dash, and then make sure wire connectors are working - i found the 2 spade when I looked again after your reply, they call it a 'temperature sending unit'.....
  1. Coolant Temp Switch- Coolant temp Sensor any diff?
    By Doc325i in forum 1991 - 1999 (E36)
    Last Post: 11-02-2004, 10:38 PM
  2. wiring the obd2 coolant temp sensor harness to the obd1 harness
    By coolcarlski in forum 1992 - 1999 M3 (E36)
    Last Post: 09-29-2004, 10:37 PM
  3. wiring the obd2 coolant temp sensor harness to the obd1 harness
    By coolcarlski in forum 1991 - 1999 (E36)
    Last Post: 09-27-2004, 10:29 PM
  4. Coolant temp sensor problem.
    By KnightRider/AMG in forum 1991 - 1999 (E36)
    Last Post: 02-09-2004, 11:08 PM
  5. adding coolant temp sensor
    By fourfa in forum 1992 - 1999 M3 (E36)
    Last Post: 03-09-2002, 11:14 PM
