Results 1 to 20 of 20
Thread: Keyless module harness help
    Apr 2019
    NJ
    2000 Z3 2.8 5spd
    So i purchased the keyless entry module, it looks like i need a wiring harness, any one have a part number. Where would it connect? The module is bigger then the empty slot, did i buy the wrong unit?
    SW Florida
    99-01 M Cpe & Rdts, X5M
    There would've been a harness, and you'll find the car's connector taped to the wiring harness somewhere under there.
    You can probably find the installation instructions online, and from that you'll get the point to point wiring diagram. If you're really lucky, maybe you can find a harness...
    YEARS ago, I put an aftermarket alarm in someone's car, and it didn't include the connector to mate with the factory piece, so all the individual wires (with pin & sleeve terminations on them) went into the factory connector without a shell. That's what you'll have to do, if you can't find the connecting harness. A bit more effort, but certainly doable.
    Oh, and it's a bit of a tight squeeze, but I've MADE that controller fit into an empty slot...
    (they're in all 3 of my cars, and I've done some installs for others too)
    Apr 2019
    NJ
    2000 Z3 2.8 5spd
    It's a 2000, i dont see any harness on the passenger side. Any chance its on the drivers side?
    Apr 2019
    NJ
    2000 Z3 2.8 5spd
    I do see this 10pin connector, is this what is supposed to connect to the module?20190609_143912.jpg
    SW Florida
    Looks like it. The missing harness would've gone between that connector and the controller (module).
    Find the pinouts online, and make your own harness__remember__neatness counts!
    Jul 2004
    Houston, TX
    36 Cylinders
    You're missing the adapter harness that should have come with the module.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Apr 2019
    NJ
    2000 Z3 2.8 5spd
    I've found the black 12 pin diagram from the car, I can't find the keyless module wiring diagram. Can someone point me in the right direction.
    Dec 2018
    Rio Arriba, NM
    01 Z3 3.0
    I was able to source a harness from eBay for my installation. There are currently no listings for one, but this listing for a module for an E36 looks to have the correct harness and is not too expensive. 112972073529
    Apr 2019
    NJ
    2000 Z3 2.8 5spd
    Thanx Mudkat, I ordered that one, I'll sell the one i have on Ebay. I'll
    Apr 2019
    NJ
    2000 Z3 2.8 5spd
    I installed the module with the 10 point harness. I did not connect any of the other wires (for the alarm). The car has an aftermarket radio and no light in the center console. I did the steps to sync the transmitter, but was unsuccessful. Am i missing something?
    Dec 2018
    Rio Arriba, NM
    01 Z3 3.0
    Apr 2019
    NJ
    2000 Z3 2.8 5spd
    I disconnected the radio switch, still not syncing. My interior light fuse was blown, noticed it when opening the door, changed it. Should the dome light come on when I open the trunk? I can drive the car with the trunk open, no warning lights, could the trunk switch be bad.
    Denver, Colorado
    MRster / Z4 M4i / X5 M50
    The dome light should not come on when you open the trunk, but the trunk light should come on. If your trunk light is on when the trunk is open, you can check the trunk switch by putting your phone, on video, into the trunk and closing the lid. The video should show the trunk light going off if the trunk switch is good.
    2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, Black Soft Top, Steel Gray Metailic Hard Top, TC Kline Double Adj Shocks with H&R Springs, Stromung Exhaust, SSR Type C Wheels. Looking for a new home.
    2022 Z4 M40i, Misano Blue Metallic, Prem Pkg, Driver Assistance Pkg
    2023 X5 M50, Phytonic Blue, Black Extended Merion Leather, Driving Asst Pro Pkg, Park Asst Pkg, Exec Pkg, Climate Comfort Pkg.
    Apr 2019
    NJ
    2000 Z3 2.8 5spd
    I don't have a trunk light, was it an option? I did see the 2 pin switches.
    Apr 2019
    NJ
    2000 Z3 2.8 5spd
    Found the trunk light, it is working. Will try to sync later.
    Apr 2019
    NJ
    2000 Z3 2.8 5spd
    I'm done, everything is going on Ebay. I will go the aftermarket route. Thanks for your help.
    Dec 2018
    Rio Arriba, NM
    01 Z3 3.0
    Sorry you couldn’t make the OEM system work. For my aftermarket installation I used Avital 2101L spliced to the vehicle end of the factory harness. See:https://www.bimmerforums.com/forum/s...Avital+keyless
    Aug 2012
    Kansas
    2000 m roadster 2010 x3
    You really need the alarm LED to know where your at and to verify response from the module when enrolling the fob.
    May 2019
    SoCal
    M3, and M Coupe
    On a 2000 M Coupe, where would the red LED plate be installed?
    Denver, Colorado
    I think it is usually in the front on the console, but if you didn't purchase your car new, it could have been moved to between the seats.
  1. Harness help...
    By AvusBluR in forum 1991 - 1999 (E36)
    Last Post: 02-04-2003, 04:23 PM
  2. Seatbelt harness help
    By Bernanke in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 08-22-2002, 01:34 AM
  3. Engine harness help
    By M3RACER in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-10-2002, 11:09 PM
  4. Remote Keyless Entry Install Help Needed
    By PDX///M in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-15-2002, 09:54 PM
  5. Harness - Help!
    By carrera in forum 1992 - 1999 M3 (E36)
    Last Post: 03-09-2002, 01:48 PM
