More pictures & videos here: https://photos.app.*******/7fXfhmzPSMf6BgD18 (replace "*******" with "goo .gl" except no space between the "o" and ".")
Located in Tennessee, USA. Working AC & windows. Stock stereo with wired aux and Bluetooth dongle/mic, H&R/Koni/M5 sport suspension, automatic transmission, very well cared for. Clean, passes emissions beautifully. Easy to drive(duh). Classic 90's luxury. It runs well. Zero leaks. I did everything in the list below except the transmission and AC. This car has been cared for and maintained (and upgraded). Im getting a different vehicle and need to part with this one. Questions? Asking $3200.
Less than 3k mi:
- Oil (15W-50 synthetic)
- Air Filter
- O2 sensor
- Injectors cleaned
- Coolant temp sensors
- Crank position sensor
- AC refilled/leak tested (works great)
- Custom intake oil catch pan (pcv)
- Windshield wipers
- Vacuum/Intake tubing (all rubber tubes including the big ones)
- Fuel filter
- Brake pads
- Repaired door cards (delamination fixed with new adhesive)
- Belts
- Back-right and front-left window regulators
- Power window rail grease
Less than 10k miles:
- Water pump(metal) + housing(metal)
- Coolant + Coolant tubing(all)
- Radiator/expansion tank
- VANOS (new from dr vanos)
- Transmission fluid
- Head + all associated gaskets/seals (original head had a crack)
- Fan clutch
- M52 valve springs
- Spark plugs + Plug boots
Less than 30k miles:
- Automatic transmission overhaul (& shift kit)
- Koni adjustable shocks (front & rear)
- H&R sport springs (front & rear)
- E34 M5 rubber bushings (all bushings)
- New tie rods
- New thrust arms
- New brake lines
- New strut mounts (front & rear)
- New Giubo coupling
- New driveshaft center support bearing
- Wired AUX port with Bluetooth dongle
Problems:
- SRS light
- ASC randomly turns off/indicator shows up
- “Rear brakelight” but there’s nothing wrong with the lights or their function
- Spot of rust on driver’s door.
Interested, PM sent.
Sold.
