Results 1 to 8 of 8
Thread: Heater blows ambiant temp air - No AC and no heat
    Feb 2019
    Lee, NH USA
    2005 BMW 525i
    2005 E60 525i cabin HVAC only blows ambient (not hot and not cool) air no matter what the temp settings are set to. Blower seems fine and AC compressor clutch appears to be engaging (I need to check temp of AC lines to see if there is anything going on there). I turn the temp up or down and it doesn't change no matter what. AC on Max, Off, Auto, whatever, it does not affect the temperature.
    I recently did a head gasket job and everything else appears fine and I have driven it for about a thousand miles or so. I ran my INPA and did get a Klima 9C55 error indicating a condensation sensor issue and have not replaced that yet as I suspect this is not the cause based on what others have reported as symptoms when that sensor goes bad.
    Suggestions please. It's starting to get warmer here in NH and after that the snow flies!
    Shawn
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    you posted in the E46 forum, I will move it to the E60 forum
    Feb 2019
    Lee, NH USA
    2005 BMW 525i
    Thanks very much. I noticed that after I posted but wasn’t sure how to move it. Gracias!
    Dec 2015
    Boston, MA
    2007 BMW 530xiT
    Sounds like you have a stuck heater control valve. Easy fix and don’t think it throws a code.
    Feb 2019
    Lee, NH USA
    2005 BMW 525i
    Could you (BostonJon) or someone point me to where I can learn how to unstick a stuck heater control valve?
    How to unstick a stuck heater control valve: Buy a new valve and replace the broken one.
    Jul 2018
    NJ
    2010 535i X-Drive
    Mar 2019
    San Quintin
    UBER
    Same sort of thing was happening to me with my 2007 530i. I discovered that if I go into the climate settings through the display unit via the turn knob on the center console, I can turn down the heat through that method and get much cooler a/c through the vents. Not sure if this is the way it's supposed to be, but on my car, that's the way I can turn it down cooler. Before I did that, I could have the turn knob right above the cd player turned all the way down and it still wouldn't be cold. So in my situation, I was getting half hot air and half cold air (a/c) until I turned down the warm input through the climate folder.
    1995 M3 (sold)
    2000 528i (sold)
    2007 530i (Daily Driver)
    2015 528i (Sunday Driving)
  1. e46 330 ci manual intermittently blows cold/warm air when ac is on. :
    By MRKINGREY in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 06-06-2015, 08:58 AM
  2. 95 318 ti Heater blows cold air
    By CSMartinUSMC in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 03-04-2007, 04:35 AM
  3. 98' 323IS Heater blowing cold air
    By brandonwiederho in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 01-13-2007, 04:12 PM
  4. No air from AC or Heater?? Please help
    By jszy25 in forum 1992 - 1999 M3 (E36)
    Last Post: 06-12-2006, 12:33 PM
  5. My AC is blowing strong cold air, heater is fuxored
    By Solidhead in forum 1991 - 1999 (E36)
    Last Post: 11-04-2005, 04:37 AM
