Results 1 to 9 of 9
Thread: Sedan rear quarter seal replacement
    Dec 2013
    MA
    Is anyone familiar with how to replace these seals on a sedan? Wasn't able to find much info by googling.
    For reference, P/Ns: 51341960915, 51341960916
    Jan 2016
    Ca
    2001 525it
    I think you have to remove tha main glass then remove the rear window guide then the quarter window would come out with the glass and gasket as one
    Peoria, AZ
    03 zhp, 97 e36m3, 04 zhp
    Where in Mass are you?
    Dec 2013
    MA
    Unfortunately no longer in MA, I'm in Chicago now.
    Jul 2012
    Atlanta, Georgia
    ∞FX37,M3a/4,94 332
    Quote Originally Posted by hli View Post
    Did you replace them yet? I will be replacing mine in a few weeks and can post a few pictures if you need them.
    [IMG][/IMG]
    Dec 2013
    MA
    No, it's on the laundry list of stuff to do for the car; I'll probably get around to it after I finish the rear end overhaul. Some pictures would be greatly appreciated.
    Jul 2012
    Atlanta, Georgia
    ∞FX37,M3a/4,94 332
    I replaced both of the window seals on my rear doors. The fixed glass seal had shrunk which was allowing water to wick into my car along the bottom of the glass. I also replace the black dum dum that is used to hold the inner vapor barrier in place. 1 roll of 15' 3M dum dum will do 2 doors(got it on Amazon).
    You will only need a few tools; Torx 20, 10mm socket/ratchet, Phillips head screwdriver, 90* pick, door panel tools, plastic trim removal tools.
    After you remove the door panel and vapor barrier;
    - remove window switch from the door panel and reattach it, you will have to raise and lower the window and it makes it easier than reaching for the front switch.
    - lower window and remove the moveable glass seal, that will expose the 3 black screws on the front vertical B-pillar trim and 1 brass color screw on the top forward of the fixed glass vertical trim.
    - remove inner belt molding and 3 metal clips, if you leave the clips in place, it can scratch window tint.
    - remove the metal pin from the plastic clip that holds the window glass to the regulator ( mine broke into pieces since it 22 years old) replace plastic clip
    continued.......
    [IMG][/IMG]
    Jul 2012
    Atlanta, Georgia
    ∞FX37,M3a/4,94 332
    - use the door panel tool to pop the regulator out of the clip, then lift the window glass up and out of the frame, place the glass in the trunk.
    - remove the two 10mm bolts (blue tape marking location)and brass colored screw from the trim piece just forward of the fixed glass
    - you will have to pull the trim down a few inches and then forward in the door a few inches, but it can stay in the door.
    - place your hands flat on the fixed glass, 1 on the inside, 1 on the outside and push forward in the door. It won't instantly move, keep steady pressure on it.
    - after you clean the dirt out, *(see next post for a better picture) dry fit the seal without the glass so you can see how the small protrusion fits into the void of the existing
    belt molding for the up/down
    - reinstall the fixed glass trim, tighten the screw first, then 2 10mm bolts.
    - lube the up/down glass slide with some white lube after you lock the glass into the clip, raise & lower glass, add more lube
    [IMG][/IMG]
    Jul 2012
    Atlanta, Georgia
    ∞FX37,M3a/4,94 332
    I replaced the seals on the other side and took better pictures of the fixed glass window seal's tab the goes underneath the belt molding. After cleaning out the dirt, I used some carwash soap and water to help it slide into place.
    [IMG][/IMG]
  1. Rear Window Seal Replacement (Sedan)
    By tfolks206 in forum 1992 - 1999 M3 (E36)
    Last Post: 12-22-2018, 12:39 AM
  2. Rear main seal (rear crankshaft seal) replacement
    By bmwpower in forum 1983 - 1991 (E30)
    Last Post: 11-14-2013, 10:33 AM
  3. transmission rear output seal replacement
    By supark in forum 1991 - 1999 (E36)
    Last Post: 11-16-2007, 01:03 PM
  4. Rear Main Seal Replacement
    By 2point5turbo in forum 1991 - 1999 (E36)
    Last Post: 02-15-2007, 08:33 AM
  5. Rear Main seal replacement
    By Ferris in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 03-03-2006, 12:14 PM
