My run flats are 245/45R19
Will I be able to install regular tires with the same dimensions?
Dont see why not.
Sent from my SM-J727T using Tapatalk
Thank you for your reply. I just thought it will be bmw/rim req to install run-flat ONLY. So if I buy 245/45R19 should be golden?
Run-flat and standard tires will fit no problem. Just be careful if you have staggered tires.
just remember ... when it is flat then you need a spare tire
I'm not promoting run-flats because there is only very limited reprieve running on a run-flat, but now you will need to find a spare to carry around with you
... forty-three years of driving before I get behind the wheel of a BMW .... and I am thinking, "why did it take me so long?"
... and then after another 4 years I can't believe that I have two of them !!
A spare...or a tire mobility kit...and possibly a paid up road side service (like AAA)...and good cell service (also paid up). All of this is will be the back-up in case of an emergency. Be wise, be prepared.
