Results 1 to 3 of 3
Thread: Software for retrofits
    Billings, MT
    2013 328i xDrive
    Hi guys, I have an e83 and I received my Bimmergeeks cable and I have BMW Standard Tools and I played around with it a little last night. I understand I can use NCS Expert/dummy to code and change vehicle preferences within the different modules.
    My question is for retrofits. I'm installing a factory alarm kit and the instructions say to code it with DISPlus or GT-1. I may eventually retrofit nav as well which also says to use DISPlus or GT-1 for coding. Can this be done with NSC Expert or do I need to look for additional software to code/activate retrofits? Possibly Progman?
    Thanks all!
    -Chris
    My e30 build thread/color change here
    Jul 2004
    Houston, TX
    36 Cylinders
    Yes, NCS Expert and WinKFP does everything as DIS/Progman would, and probably better anyways.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Billings, MT
    2013 328i xDrive
    Thank you! I did a bit more research and learned how to add the DWA to the VO, but I couldn't find any clear instructions on how to code a module that I've added to the VO. Once I add it do I have to go into a specific ECU and then change the setting to "aktiv" for DWA? What module would that be in? EKM possibly?
    -Chris
  1. Retrofitting OEM NAvigation: Changer/Software?
    By RYDAJO in forum 2001 - 2006 M3 (E46)
    Last Post: 10-19-2011, 11:06 AM
  2. Shark Injector VS. Dinan Stg II Software
    By PHAT 328 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 06-06-2001, 02:20 PM
  3. Software for OBD 11
    By S/CDaveNY in forum 1992 - 1999 M3 (E36)
    Last Post: 04-09-2001, 08:02 PM
  4. Conforti software - original Shark OBDII re-program VS. Shark Injector
    By CaptainPlanet in forum 1992 - 1999 M3 (E36)
    Last Post: 03-30-2001, 12:42 PM
  5. Best Shiftpoints & Performance Software!
    By Bob ///M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 03-13-2001, 11:28 PM
