56888626-10219472555949404-301622573806911488-n.jpgHello im just finishing up my second BMW turbo build a 2001 Z3 M54 and need one last part ,
im running a top mount GTX3582R and need the compressor outlet to turn forward at 90 degrees,
Im looking for a aluminum 2.5 inch cast or tubing with a tight 90 degree turn that can be welded to
my compressor housing i see it done all the time but cant seem to find where to buy one, what are you
guys using to do this? Something like in the photo. Thanks
2001 Z3M S52 OBX T4 Top Mount, GTX3582R T4 1.06, 66MM Compressor, 3 Inch IC Pipes,HPX, Wiseco 8-1, Ported Head, Carrillo Pro Rods, CES Cut Ring, 3.5 Exhaust, ARP, Big FMI, Turbonetics Gate Fender Exit, 2 Walbro Pumps, UUC 6 Puck Ceramic, Aluminum Flywheel. With working A/C.
I have an account with vibrant. I can order you one. Msg me if you want.
1989 535i - sold
1999 M3 Tiag/Dove - sold
I think I have a compressor housing with the 90° welded on already that I can sell you. I’d have to look for it.
Cxracing sells it. I bought a cast aluminum one off of eBay and the quality looks pretty crappy
