Results 1 to 8 of 8
Thread: 2014 X3 F25 Clunk from Right Rear
    Mar 2013
    Mesa, AZ
    2014 BMW X3 XDrive 28i
    I'm experiencing a light clunk from the right rear when turning right at low speeds, especially over a dip or bump. Noise is infrequent, probably 50% of the time. Nothing loose on the inside that could be causing the noise. Any leads or ideas would be appreciated.
    Mar 2019
    ATLANTA GA
    456 X3s
    Rear diff fluids change?
    Sent from my SM-J727T using Tapatalk
    Mar 2018
    Washington DC
    2002 BMW 325xi
    What did you do to fix this problem?
    Quote Originally Posted by RTAZ View Post
    Mar 2013
    Mesa, AZ
    Unfortunately, I haven't had time to give this much more attention. I don't think the sound is coming from the differintial, soinds more like something in the suspension, but nothing seems loose or worn.
    richardodn's Avatar
    richardodn is offline Old Guy BMW CCA Member
    Moderator
    Nov 2008
    Lakewood, CO
    20 440ix cab, 12 X3 35ix
    It's likely something made out of rubber; bushing, shock mount, etc.
    "Howdy, Folks!"
    Mar 2019
    ATLANTA GA
    456 X3s
    Then there's the steering angle sensor...but this can go on all night with a BMW...Tell us ...what does your coder scanner say?
    Mar 2013
    Mesa, AZ
    What I thought was a noise coming from the rear end, turned out to be my liftgate that needed to be adjusted. Sounds crazy, but that fixed the problem. The adjustment bumper on the right side was turned all the way in and was not holding the liftgate tight enough to keep it from flexing and making what seemed like a clunking coming from the rear differential or suspension.
    Jun 2019
    Richmond,VA
    '12 BMW X3 28i (F25-N52)
    Thanks I was having a similar issue with 2012 X3 and will look at this when I get home today.
  1. 2014 X3 F25 tailgate emblem housing tool
    By j a maddigan in forum 2003+ X3, X4 (E83, F25, F26, F97, F98, G02)
    Last Post: 10-25-2018, 09:35 AM
  2. Clunking Noise (Right Rear) / DSC,ABS,BRAKES Warning Lamp
    By SkiDooSnipe in forum 1999 - 2006 (E46)
    Last Post: 01-16-2015, 08:20 AM
  3. Clunking from right rear; not the usual suspects
    By AndrewH in forum 1992 - 1999 M3 (E36)
    Last Post: 11-27-2014, 10:45 PM
  4. Clunking from right rear wheel
    By kahmedsid in forum 2002 - 2008 Z4 (E85, E86)
    Last Post: 05-09-2012, 01:04 AM
  5. 96' Z3 1.9 clunking in right rear in 2nd gear
    By Cwoody in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 06-06-2010, 11:54 AM
