Results 1 to 5 of 5
Thread: M10 with twin 40’s
    Jun 2019
    Colchester,essex
    BMW e21 316 BMW e21 320
    M10 with twin 40’s
    Hello
    I’m after some advise on the best way to proceed with fitting Weber 40’s on my currently standard 1983 316 1.8
    So as far as I’m aware fitting the Weber’s alone will not provide great results due to the small valves/ports on the m10 1.8 head
    The way forward seems to be the e30 318i head
    Has anyone does this that can advise me on which head I need.....
    Is there a particular year to use or avoid
    Is there a particular code to look for
    Will fitting the e30 head require other modifications to the timing chain or other components?
    Any info is greatly appreciated
    Regards
    Iain
    Jul 2017
    Dinslaken, NRW, Germany
    Hello, using the E30 head on a E21 block needs no mods. Pistons for e30 and E21 are the same. You can use every E30 head with code 318i on it. Only thing to do is using a electric fuel pump to feed your webers. The 318i head has no holes to mount the mechanical fuel pump. Regards Andy
    “Speed has never killed anyone. Suddenly becoming stationary, that's what gets you.”
    Jun 2019
    Colchester,essex
    Thanks for the info 👍🏻👍🏻
    Jun 2019
    Colchester,essex
    Do you know what kind of results I should expect with this set up before good down the route of lightened flywheel etc
    Jul 2017
    Quote Originally Posted by Iaine21 View Post
    Hello,
    cant tell you about power just with the carbs. Mine was a complete change and it was all done together. I used the E30 / 318i head (bit ported and smoothed out), Weber 40 DCOE, a Schrick 292 cam and Martelius 2" exhaust in combination with a Alpina A4 replica downpipe what was done for a 2002 and needs minor mods. With all that stuff i got 122 hp at the rear wheels. I think with head and carbs only you could expect around 12 to 15hp more. The numbers let you not see how much more free the engines feels now. It revs over 4k with a totally new speed till redline. First three days i was only driving around with a big fat smile every time i hit the pedal.
  1. Twin Weber DCOE 40 mm sidedraft carburetor setup for M10 - No Longer Available
    By C.Hutch in forum Engines, Performance Parts & Software
    Last Post: 07-04-2015, 06:31 PM
  2. Replies: 6
    Last Post: 08-14-2008, 06:20 AM
  3. Stock fuel pump enough for twin 40's?
    By 76duece in forum 2002
    Last Post: 11-14-2006, 11:15 PM
  4. dual weber 40 dcoe for m10
    By sj413 in forum BMW Parts For Sale
    Last Post: 04-14-2006, 12:00 AM
  5. Twin Turbo M10....
    By BoostedE21 in forum 1975 - 1983 (E21)
    Last Post: 10-13-2004, 07:05 PM
