Results 1 to 6 of 6
Thread: A/C lines for your swapped car
    Aug 2009
    CA
    E36
    I just got done swapping my E36 with a 2JZ and looking into getting my A/C up and working. My question is has anyone made adaptor fitting for the firewall or are people just using the stock fittings and welding them? Any info would be great if anyone knows.
    Mar 2019
    Milwaukee, WI
    '99 LS-swapped 323i vert
    I don't have a good answer to your specific question, but I have seen a variety of approaches taken. My approach will be to use BMW components except for the compressor, so I intend to buy/make an adapter on the compressor connections only. Have you seen this thread: https://www.bimmerforums.com/forum/s...h-LS1-E36-swap ? Much of the thread is about getting it to play nicely with the LS1 computer, but there is also lots of good info on the connections. (Some of the info in the beginning of thread is dated.)
    What compressor are planning to use?
    Diving in at the shallow end!
    Aug 2009
    CA
    E36
    Quote Originally Posted by motorV8ed View Post
    Thanks for that bit on info.
    The plan so far is to use the compressor that came with the engine and the rest of the BMW stuff
    IM guessing no one makes a A/C firewall adaptor but I thought id give it a try
    Jul 2013
    FL Gulf Coast
    E36 - 1998 328iS - LS2
    Quote Originally Posted by dirtdiggler View Post
    IM guessing no one makes a A/C firewall adapter but I thought id give it a try
    Just grab a set of old hoses with the firewall connection from the pick-and-pull or a part out, if you don't have your old hoses.
    Do a Google search or ask around to find a comprehensive local hose shop. They can easily graft the stock ends onto new/custom hoses/lines for you.
    The hose shop I use makes everything from huge hydraulic hoses for garbage trucks and heavy equipment, to small brake lines, to custom A/C hoses. They have hundreds of bins filled with various fittings.
    Just for reference, this is the local shop I use. There's only a few pictures on their Google listing but the few pictures give you an idea of what a well equipped hose shop looks like.
    Aug 2009
    CA
    E36
    Quote Originally Posted by TipsyMcStagger View Post
    Just for reference, this is the local shop I use. There's only a few pictures on their Google listing (and the first picture is definitely not of their shop) but the few pictures give you an idea of what a well equipped hose shop looks like.
    Thanks a bunch that really helps, I have no clue about A/C stuff.
    Any chance you know what the cost of the two main lines should cost to make? I just don't wanna over pay.
    Jul 2013
    FL Gulf Coast
    It's hard to say. It really depends on what you're having done but I'd anticipate a few hundred dollars.
    You can probably get it done fairly inexpensively if you don't care about how they're routed. It's mainly the time that's involved that you're paying for, though silver-solder is not inexpensive.
  1. Parts for a euro M3 swapped car
    By M pwrd in forum 1992 - 1999 M3 (E36)
    Last Post: 05-25-2006, 04:44 AM
  2. Auto/Manual Swap Car Preping
    By JDCMotorwerkz in forum 1991 - 1999 (E36)
    Last Post: 02-18-2006, 05:13 PM
  3. m50 swap! car doesn't start
    By Clbsprt ti in forum 1991 - 1999 (E36)
    Last Post: 11-01-2004, 08:53 AM
  4. JPM and Jeff Gordon to swap cars on 6/11
    By fredo in forum Professional Motorsports sponsored by Bimmerworld
    Last Post: 06-22-2003, 03:35 AM
