Results 1 to 25 of 31
Thread: A/C problem Again
    birmingham,al
    2001 3.0 Z-3 RD'STER
    A/C problem Again
    A few weeks ago, the A/c stopped blowing cold air. I took the car to a tech shop and he said Schroeder (is that spelled right) valves needed replacing and the Freon was leaking from there. After replacing the valves and vacuuming the system and filling with freon, the a/c was blowing cold air. Twice, now, the system blew warm air and after awhile began blowing cold air then warm air again. Is there another leak somewhere. The compressor kicks in. The expansion valve has been replaced some years ago, so maybe the evaporator coil is bad. The next step is to take the car back to the tech shop and have it checked out. Any suggestions/ideas why the a/c system is doing this??
    May 2019
    NJ
    98 M Roadster
    Hey Morrie, speaking as a career refrigeration specialist and not car person even tho I am trying to work on that...I’d say if you had a leak you would NOT go from cold air to hot back to cold. If it was leaking “usually it just be a steady decline in the warm direction”. Cold than warm than cold to me sounds more like your compressor is turning off and on before the temp is satisfied. My vibe is more electronics vs mechanical. If your evap was bad it too would just be more of a straight to warm not a seesaw effect. Once again I responded with refrigeration tech info NOT car mech info.
    Curious too, when you say cold than warm than cold. What’s the time frame on this swing. A day or two or at a traffic light? City traffic or highway? Did you all know doing 70mph with the AC ON at that speed your car would cool your house. In traffic it barely cool a hampster cage.
    May 2019
    NJ
    98 M Roadster
    The valves you speak of should have caps. So even if they were bad they shouldn’t have caused your leak. The valves you speak of are the same as your tire valves. Schrader valves.
    May 2012
    USA
    2000 BMW Z3 2.3 Auto
    can you check the pressures with the gauge? May be the evaporator is freezing up and it is sensing it and turning off compressor (or with low pressure sensor).
    Feb 2014
    Galt,CA
    2002 M Coupe
    Are you aware that if you are accelerating briskly that the AC compressor shuts off? It will blow warmish air until you reach a cruising speed, then the compressor will engage again and cool air ensues. Effectively the car saves all of the horsepower for driving the wheels when needed. It's hard-coded in the electronics somewhere.
    Marty
    birmingham,al
    This is about the 3rd time this has happened this week. I drive about 15-20 minutes from my house to the gym in light traffic not over 55 mph in light traffic stopping for few traffic lights. It happened going to the gym and about 2 hours later when I left the gym. I checked to see that the compressor was turning over when I got home. It was but no cold air. BTW the tech said the rubber O-rings in the schrader valves tend to collapse over time. I just replaced the valves. I was told that I had a leak around The valves years ago so they were replaced. This is the 2nd compressor on the car. I hope it's not the evaporator coil. That involves removing the dash....been there done that. Thanks guys for your input. I'll take the car for a spin on the interstate Sunday and see what happens. I'll leave a response on this thread.
    Tallahassee
    1998 Z3 M Roadster.
    A/C problem Again
    You need to find a good AC tech.
    Oh, and to remove the evap does not require the dash to come apart, just the glove box needs removing.
    The easiest evap swap I have ever done is on a Z3.
    Without a set of LP and HP pressures. This is all just guesswork.
    birmingham,al
    Thanks Chief for the information about the evaporator coil. Yes I will.take my car to another tech.
    Sent from my SM-G920V using Tapatalk
    May 2012
    USA
    Evaporator, Yes.. I think only Z have it at a location which does not need the dash to come out.
    I had to replace everything except the lines. If compressor is on, then there is sufficient refrigerant in it. You really need the gauges to fix this.
    For me, the evaporator, condensor both were leaking. Easy to find with the dye and yellow glasses with that light
    May 2019
    NJ
    98 M Roadster
    I agree. Some pressures would be the be best to tell everyone what’s going on.
    birmingham,al
    Thanks man....appreciate your input.
    birmingham,al
    Today I was prepared to take my car to the tech. When I started the engine and I pressed the a/c button I could hear the compressor turn on. to my surprise Cold air began flowing from the vents. I drove about 5 miles to the grocery store, parked the car, did some shopping and then drove home. The A/c never stopped blowing cold air. I have no idea what happened but I am thankful for this unexplained happening. I will hold my breath when I start the engine tomorrow.
    birmingham,al
    Quote Originally Posted by MORRIE View Post
    A/C is back to normal..
    .dont have a clue what happened to make it blow warm air.
    May 2012
    USA
    How high was the temperature and humidity?
    Any loose connection on the high low sensors caused this?
    Do you have DIS? Can you scan and see any stored error codes...Not sure if it will record anything for this
    birmingham,al
    No clue what caused it. Humidity was normal no sensor malfunction and no codes came up.
    Mar 2016
    Detroit
    Z4M Coupe
    It could be a restricted expansion valve. I believe it’s recommended you change the valve and the drier when doing an AC refresh. Could it be possible that the valve is sometimes restricted and sometimes not causing fluctuations in refrigerator to the evaporator therefore resulting in sometimes hot and sometimes cold air. A set of manifold gages and pressure readings will help diagnose.
    birmingham,al
    Thanks for all comments/suggestions. However the a/c system has resolved itself. It is working again.
    Oct 2012
    Louisville, KY
    1997 BMW Z3 1.9L 5MT
    As Mr Bingley deduced in your other switch thread, alternating cold and hot could be from the evaporator icing up and then defrosting, due to the blower not working on 1-2-3 because of the resistor. Until a new resistor comes, see if running the AC on 4 keeps it working.
    BMW MOA 696, BMW CCA 1405
    birmingham,al
    Quote Originally Posted by milamookie View Post
    I put in new expansion valve and drier and compressor about 5 years ago.
    Imperial, PA
    1998 Z3, 2.8; 2000 328Ci
    Just make sure your cooling fans are working typically. If your electric fan is shot, then at stop lights and low speeds and certainly during start-up, you will get ambient air out of the vents. As long as you are driving, your AC will feel normal. I was experiencing these symptoms on my 328Ci, and eventually tackled it to the failed electric cooling fan. Once replaced, all was normal.
    birmingham,al
    No it doesn't but was worth a try.
    birmingham,al
    The problem is back....cold air then warm air. The expansion valve needs replacing. Of course a new drier since the lines will be opened. I wonder should I replace evaporator coil while I have access to that as well.
    Tallahassee
    1998 Z3 M Roadster.
    Hell I would.
    It’s a known issue.
    May 2012
    USA
    Don't need to replace the evaporator coil unless it is leaking. Expansion valve and its HNBR O-Rings. Get a packet of those O-Rings from Autozone. Do a thorough check for leaks with the yellow glass and light and replace as needed. Also make sure the drain in the evaporator drain is clean and it is draining water.
    Within 3 years, it is blocked again? Any residue in the lines?
    Washington, D.C.
    S54 e36/8
    I know you got lucky and yours started working, but both of my cars, the M5 and the M Coupe will exhibit this problem when it's VERY hot outside.
    The AC will work if you are driving on the highway and there is constant load on the system. If you are in stop and go traffic in the city, it'll get warm when idling or stopped at lights.
    Very annoying. Would like to know what the fix is. One of the only areas of cars I'm not familiar with.
    Thanks!
  1. 80 732i problems again!
    By chilly in forum 1995 - 2001 (E38)
    Last Post: 05-04-2004, 11:36 AM
  2. a;lsdkjfsdl;.....FREAKIN HFM problems again
    By 95MMM in forum 1992 - 1999 M3 (E36)
    Last Post: 01-05-2004, 11:36 PM
  3. Steering problems--again
    By daddycam in forum 1991 - 1999 (E36)
    Last Post: 11-16-2001, 01:43 PM
  4. Steering problems--again
    By daddycam in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 11-13-2001, 01:43 AM
  5. V1 problem again, please HELP
    By Rahul325 in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 08-14-2001, 05:28 PM
