Bavarian Soundwerks
Results 1 to 3 of 3
Thread: Power Windows / Dash light issues
    Mar 2019
    Texas
    1985 325e
    85 325i
    My power widows and dash lights work intermittently. Cigarette lighter also has no power. I’ve checked all fuses with a continuity tester and have checked the connections as well. Everything seems ok. So the problem obviously lies elsewhere.........
    I was told that I may have a bad ground somewhere......a seemingly common problem (again, as told)...but just “where” I have not a clue. Is there a common ground for both systems and if so, just where is it located.
    If there’s something else I need to check, I’m open to all the suggestions you have to offer.
    Sep 2008
    West London/Heathrow - UK
    03 530dT - Ex Police Car
    Hi,
    You need to check all wiring for continuity, and breaks, loose connections, chafes. As you've done part of this ,check things like power window motors, cluster display internal connections. Get the help of a local reputable auto electrician. Put this question also in the E30 section as it's nothing to do with car audio and associated electronics.
    Cheers, Dennis!
    Peoria, AZ
    03 zhp, 97 e36m3, 04 zhp
    Is there any aftermarket equipment that is installed in the vehicle? r3vlimited forum is your friend.
  1. Power Window Button Light doesnt light up :{
    By ghettozn in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 08-23-2006, 09:42 AM
  2. Weird (minor) dash lighting issue
    By GuinnessDraught in forum 1988 - 1996 (E34)
    Last Post: 08-21-2006, 09:11 PM
  3. Power Window Button Light
    By ghettozn in forum 1991 - 1999 (E36)
    Last Post: 08-19-2006, 02:08 PM
  4. Replacing power window etc. lights with LEDs
    By Rectifier in forum 1983 - 1991 (E30)
    Last Post: 02-20-2005, 05:46 PM
  5. Power Windows' switch light
    By hamz in forum 1991 - 1999 (E36)
    Last Post: 08-30-2002, 12:23 AM
