Results 1 to 7 of 7
Thread: automatic transmission stuck on 4th gear
    May 2017
    Athens.Greece
    1997 e36 325 M/T
    hello guys! when i put my car on <<D>> its start with 4th.. if i go my gear on <<1>> its shift down on 3rd..
    when select <<S>> or <<M>> buttoms doesn work! the light switch but not stuck and car is stack on 4th!
    any idea??
    thanks for all
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Which transmission do you have? ZF 5HP18, as it is a EURO spec. car? Which engine? Built year/month?
    My Cars: E36
    please add those data to your profile, E36 is not enough to help you.
    In case it is a 5HP18, check the shift selector valve, that breaks sometimes https://www.bimmerforums.com/forum/s...-rod-is-broken
    troubleshooting 5HP18 http://www.bimmerboard.com/forums/posts/1214743/
    May 2017
    Athens.Greece
    1997 e36 325 M/T
    hello,its my brother car
    this car is 1993 with gm 4l30e and m50b20 engine
    May 2017
    Athens.Greece
    1997 e36 325 M/T
    Today the car when i press "D" start with first gear but change until 4th gear very fast after i change from N to D
    May 2017
    Athens.Greece
    1997 e36 325 M/T
    Hello!! My e36 320 with gm 4l30e change all gear.. When car is cold is work fine but when is hot and i run up to 120kmh, the car not shift down... Is stuxk on 4th gear
    Jan 2005
    Japan
    Did you check the ATF fluid level? When did you last time change fluid filter and ATF?
    check if the cable for the gearshift is correctly installed on the transmission side
    May 2017
    Athens.Greece
    1997 e36 325 M/T
    Hello my friend, i change atf before 6 days
    I will check the cable! Maybe solenoid valves??
  1. Transmission Stuck in 3rd Gear
    By o3clipsegts in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 07-31-2018, 11:18 PM
  2. Transmission Grinding 1st - 4th gear and 6th NEED ADVICE!
    By Awayne123 in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 12-03-2015, 05:49 PM
  3. Transmission stuck in 3rd gear
    By RAYZR in forum 1996 - 2003 (E39)
    Last Post: 05-20-2012, 01:00 AM
  4. getrag 265..stuck in 4th gear
    By guyin916 in forum 1988 - 1996 (E34)
    Last Post: 06-10-2005, 10:23 PM
  5. transmission stuck in 4th
    By roderage in forum 1983 - 1991 (E30)
    Last Post: 06-03-2004, 09:52 PM
