I am listing this for a friend of mine. All interested parties should email him directly at michaelccleary@gmail.com. Now for the details...
The car has 84,500 miles on engine and chassis, I have put less than 3,000 miles on it in the past 4 years. The car is potentially streetable (just needs a horn) and has original seatbelts. I had it registered and drove to and from the track for the first season but have trailered it since.
I purchased the car from a seller in North Carolina who had done most of the necessary work to set up the car as an HPDE track car prior to my purchase. Key upgrades that I added were a refreshed cooling system, Stoptech Front BBK, new driver side racing seat, new LTW wing, new set of squared 17” racing wheels, and refreshed power steering kit.
The car recently had a fresh set of Bridgestone RE71R tires installed which have 1 track day (4 sessions) on them, as well as new rear pads (Pagid Yellow with 1 day on them) and a full Stoptech front Big Brake Kit (2 days on the front brakes) with Pagid Yellow pads.
The car is in great shape and is ready to go for this track season. I did one track day with it this year with PCA in April of 2019 to ensure everything was running smoothly and there were no issues.
List of Upgrades from when I purchased in 9/2015
- LNA Enterprises: Roll Cage (painted, very nicely done) [$2,400.00]
- JRZ RS1 single adjustable dampers [$2,500.00]
- Rogue Engineering DMS Exhaust [$619.00]
- Ground Control Articulating Rear Perch [$244.00]
- Rogue Engineering Rear Shock Mount [$104.00]
- Hypercoil - 2.25" 6 inch 500f [$150.00]
- Hypercoil - 2.25" 6 inch 650r [$150.00]
- Bimmerworld Race Studs (rear provided not installed) [$199.00]
- Front Suspension Overall [$ 415.00]
- Ground Control Adjustable Rear Lower Control Arm [$299.00]
- Bimmerworld Stainless Steel Brake Lines [$120.00]
- Power Flex Rear Subframe high durometer [$180.00]
- Bimmerworld Adjustable sway bar links [$109.00]
- Powerflex rear trailing arm bushings [$75.00]
- Sparco steering hub [$73.00]
- Releasable steering wheel hub [$125.00]
- Bimmerworld High Energy Cage Padding [$67.00]
- Solid brake guide kit [$54.00]
- Allview rear view mirror [$60.00]
- Torrington bearing kit [$50.00]
- UUC Lightweight Flywheel/Clutch Kit [$1,098.00]
- UUC Rear rotors [$155.00]
- UUC Short Shifter [$355.00]
- UUC Clutch Stop [$55.00]
- UUC Strut Brace [$279.00]
- AFE Magnum Force Air Intake [$273.00]
- TMS Swaybar set 30mm/24mm [$523.00]
- Turner Motorsports DSSR [$116.00]
- Turner Motorsports Delrin/aluminum diff mounts [$141.00]
- Turner Motorsports Aluminum Pedal Set [$170.00]
- Vorshclag Polyurethane Comp Motor Mounts [$268.00]
- Vorschlag Camber/Caster Plates [$379.00]
- Momo Steering Wheel [$247.00]
- Momo Shift knob/book - CF [$142.00]
- OMP XL Race Seat - 9/2011 date [$1,800.00]
- Optima Yellowtop AGM battery [$250.00]
- VAC Floor Seat Adapters [$220.00]
- Schroth 6 point harness (2017) [$700.00]
Installed since I purchased in 9/2015:
- Stoptech Front Big Brake Kit w/ Pagid RS29 (Yellow) pads (2 track days on them) [$2,196]
- Pagid Yellow rear pads and rotors (1 track day on them) [$376]
- Fluidyne Race Radiator [$600]
- Mishimoto expansion tank [$109]
- Off Camber Autosport Power Steering Upgrade Kit [$349]
- Sparco Ergo 2 Racing Seat (DriverÂ’s side) [$995]
- AbrahamÂ’s Motorsport E36 LTW Wing [$649]
- Apex Race Wheels ARC-8 - 4 x 17x9 ET42 [$1,122]
Asking $15.5k OBO.
Current Stable:
2016 Cayman GT4
1995 E36 M3 Dakar Yellow (NASA GTS2)
1994 E36 325i (AER)
1988 E30 M3 (Alpine White)
Where is car located?
Car is in Philadelphia, PA
