Results 1 to 5 of 5
Thread: Front caliper removal
    Jul 2017
    RI
    2008 X3
    Unhappy Front caliper removal
    I'm having a problem removing the front caliper on my '13 X3. I loosened it using a #7 bit but the bolt won't come out of the sleeve. What am I doing wrong?
    Michigan
    2005 325Xi
    The pads are probably still clamping the rotor. Take a decent size screwdriver and put it thru the center hole in the caliper, into one of the slots on the rotor and pull toward you a little. Doesn't need much, just enough to get the pads over the little lip on the rotor.
    Jul 2017
    RI
    2008 X3
    The outside pad is flopping but the caliper isn't coming off the bracket because the bolts aren't sliding out.
    Michigan
    2005 325Xi
    The slide pins tend to stick in the rubber sleeves. Maybe if you pull them out a little, they'll clear the threads completely. Either that, or the caliper is seized on the sliding pins.
    Jun 2010
    Albuquerque
    2015 BMW 740Li xDrive
    Quote Originally Posted by X83bimmer View Post
    Try grabbing the recessed allen key bolt with a needle nose pliers to pull out. You'll need to get it moved a little to grab it with the pliers.
  1. Help-Front Caliper Removal
    By mikeeee in forum 2004-2010 (E60,E61)
    Last Post: 08-08-2010, 11:21 PM
  2. Front strut removal
    By martin23 in forum 1983 - 1991 (E30)
    Last Post: 03-14-2003, 03:56 PM
  3. WTB: e34 540 front calipers and rotors
    By E28TOM in forum BMW Parts Wanted
    Last Post: 12-10-2002, 09:42 PM
  4. WTB-E36 M3 front calipers
    By MaDoX in forum BMW Parts Wanted
    Last Post: 10-18-2002, 02:28 PM
  5. Seized Front Caliper Woes
    By jww///95 in forum 1992 - 1999 M3 (E36)
    Last Post: 08-01-2002, 03:14 PM
