The drivers side front seatbelt (RH since I’m in OZ) is slow at retracting, and I don’t feel the tensioner work when I start driving.
Is there a simple fix for this?
It's common for the seatbelt to twist, and then pull the twisted seatbelt inside the B-pillar, where the twisted seat belt then crates more friction that the roller can't overcome. If you pop the B-pillar trim off, you can see which way it's twisted. And if it isn't, you're halfway to being able to replace the roller.
