Results 1 to 6 of 6
Thread: M3 down - running like crap, Adaption EEPROM codes
    Oct 2005
    Sneaky Falls, NY
    dakar
    The 2002 M3 has been sitting for a bit due to an SMG issue, getting back to looking at it and a new problem popped up, starts up, revs up and down a few times till it dies. checked the idle posistion sensor, ohms out well for the most part, has a few drops but nothing horrible.
    Codes from INPA (google translated to english)
    any ideas on whats going on?
    E R R O R M E M O R Y R E P O R T
    Date: 05/27/19 17:52:58
    ECU: MSS54DS0
    JobStatus: OK
    Variant: MSS54DS0
    RESULT: 4 errors in error memory!
    155 internal: Adaption EEPROM master
    Error frequency: 1
    Logistic counter: 40
    Engine speed 0.00 1 / min
    relative filling 0.00%
    COOLING WATER. 20.00 degrees C
    Supply voltage HR 13.00 V
    occurred before (rel. BZ) 0.00 h
    No fault memory saved
    Error currently not available
    sporadic error
    44 Signal active oil level sensor
    Error frequency: 1
    COOLING WATER. 5.00 degrees C
    Total air mass 0.00 kg / h
    0100 - Line break or value is missing
    Error currently available
    static error
    156 internal: Adaption EEPROM slave
    Error frequency: 1
    No EWS code stored
    sporadic error
    177 MIL External Info
    Error frequency: 1
    COOLING WATER. -18.00 degrees C
    Lambda Adaptation Offset 2 1.86 ms
    MIL request by SMG
    sporadic error
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    And if you clear all the codes, and go for a re-start, do they come back?
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    May 2019
    jordan, ny
    1998 740il, 2011 F250 6.
    we reset and the codes returned. swapped the battery with a new one, reset again and tall the codes went away other than a temp sensor need to road test to see if it holds, fingers crossed!
    dworthy's Avatar
    Nov 2010
    Yeah, a weak battery can cause funky problems with the electrical systems on these cars.
    How old was the battery?
    Darin
    Current:
    Past:
    M-Flight Member
    May 2019
    jordan, ny
    Hard to say, battery was with the car.
    dworthy's Avatar
    Nov 2010
    Most of the time, there will be a date stamp either on top or the side of the battery. Mox-nix as the Germans say, for you have a new battery now.
    Did you check to see what the alternator output is/was?
    Darin
    Current:
    Past:
    M-Flight Member
  1. Fault Code Truck runs like crap please help!
    By RealEyez in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 02-03-2010, 12:07 AM
  2. Please help with diagnosis: 97 M3 runs like crap when it's hot outside
    By scoutmasterdave in forum 1992 - 1999 M3 (E36)
    Last Post: 01-23-2010, 12:30 PM
  3. Unknown fault codes, running like crap
    By fivaxis in forum 1992 - 1999 M3 (E36)
    Last Post: 11-17-2006, 10:37 PM
  4. 99 M3 Down on Power, BMW Code Scaner Wanted
    By cessna150mpilot in forum 1992 - 1999 M3 (E36)
    Last Post: 09-18-2006, 08:18 PM
  5. 97 M3 runs like crap when it gets hot outside, please help...
    Last Post: 07-09-2006, 06:42 PM
