Hi,
I have a set of ground control weight jacks for an e36, setup for use with stock style springs. $125 + shipping
They are black, have maybe 5k miles of use and are probably 5 years old...below are some pictures of the rear ended in the car, you can kind of see the adjuster on the bottom of the upper control arm. I’ll have them out tomorrow for better photos.
I believe the springs pictured are eibach and can be included with the weight jacks for a small sum of $45 the whole setup was from a ground control coil over set but the fronts are gone. Upper spring pads included and where replaced when the weight jacks where installed.
Lastly a pair of Koni Sports for the rear of an e36. $40, had rebound but I’d have them redone. —— Konis have sold
Call or Text
502-909-6744
