Results 1 to 7 of 7
Thread: Help with
    Mar 2019
    uk Canterbury Kent
    2004 BMW E46 convertible
    Help with
    (1) why is my seat belt keep Flashes on & my Cruise control STAYS ON AND it turns my radio off on my e46 bmw 2004
    (2)
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    The E46 is rolling computer. Whacky voltages cause whacky issues. The first thing I recommend you check is the electrical system. Google “BMW E46 hidden obc functions.” Test #9 shows the voltage as seen by the engine computer (DME in BMWspeak). Record and report the voltage when the:
    - ignition is in the run position but with the engine off
    - engine idling
    - engine revving at 2000rpm.
    Also, how old is the battery?
    Mar 2019
    uk Canterbury Kent
    I will have to get back to you on that one
    Jan 2016
    Ca
    2001 525it
    Could be a faulty ignition switch.
    Jan 2017
    USA
    E21, E46
    ^ i have seen this
    Mar 2019
    uk Canterbury Kent
    hello MarcoZandrini ty for getting back to me sorry it has been a week or more but I been so busy but I did it & it is 142 with the engine on and 128 engine off but I just did it with the engine idling ?
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Those voltages are fine. Someone mentioned the ignition switch. I’m skeptical as the gauge cluster is getting what appears to be proper voltages. However, you could remove the switch and clean the contacts with a relay contact file and electrical contact cleaner. The switch it located on the opposite side of the steering column from where you insert the key. The two parts-the ignition key lock and the ignition switch-are connected by a plastic rod. Basically, you need to remove the underside of the plastic cover that surround the steering column at the steering wheel. That’ll give you access to the switch itself. Disconnect the ground/earth/negative cable from the battery. Then clean the contacts. You may have to remove the switch from the column. Go to www.realoem.com and enter the last 7 characters of the car’s vehicle identification number. Hit enter and bookmark the page. Scroll down to steering. Click on the icon and scroll down to see the parts involved.
  1. Help with door lock
    By JackH in forum 1991 - 1999 (E36)
    Last Post: 02-15-2008, 06:39 PM
  2. Reiger or M3 Kit w/ LTW addons ?? help me
    By M3corey in forum 1991 - 1999 (E36)
    Last Post: 11-21-2007, 09:25 AM
  3. HELP guys!
    By outkastaliens in forum 1991 - 1999 (E36)
    Last Post: 02-27-2001, 04:40 PM
  4. Kevlar I need PRICES on ActiveAUTO STUFF!!!!!! HELP
    By mt3ch in forum 1992 - 1999 M3 (E36)
    Last Post: 02-27-2001, 01:39 AM
  5. Thanks to all guys for all help
    By Sean~328i//EastBay in forum 1991 - 1999 (E36)
    Last Post: 02-26-2001, 08:30 PM
