RM European Auto Parts
Results 1 to 5 of 5
Thread: 2007 e90 328i overheated - options?
    Jun 2008
    LA
    2008 528i
    Hi.
    I know is tricky to fix these engines once overheated.
    any point trying to resurface the head and reinstall the head gasket or just buy another engine?
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Describe the overheating event. How long was the engine run after you noticed it overheating? Did you see white smoke out the exhaust? Does the engine run? Shutting off the engine right as it starts to overheat can save it.
    Jan 2016
    Ca
    2001 525it
    Is the electric fan on at high speed, did it loose coolant? We haven't had to replace one engine because of overheating in this model
    Right. The N52 engine will usually turn itself off before it turns into a boat anchor. I have never replaced a single N5x engine due to overheating.
    Jun 2008
    LA
    2008 528i
    Quote Originally Posted by White94RX View Post
    so guess what, this is exactly what happened. The engine turned off but I'm not sure how and why (someone else was driving).
    And now I replaced the affected hose and guess what? It is back alive.
    Incredible!
  1. Halogen headlight assembly replacement tips- 2007 E90 328i sedan
    By ChefCahill in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 07-06-2018, 08:45 AM
  2. 2007 e90 328i - rough idle
    By Ms.Nika in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 06-20-2018, 07:33 PM
  3. 2007 E90 328i
    By Tradd in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 05-13-2013, 11:26 PM
  4. Roll window up then goes down halfway. 2007 e90 328i
    By smokinjoe380 in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 03-04-2013, 09:41 AM
  5. help with 2007 328i coupe options
    By chriscpm in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 05-29-2007, 05:00 PM
