Results 1 to 4 of 4
Thread: 5 series driveshafts. e28 and e34 & need e34 diff
    Aug 2017
    USA
    1990 BMW 535i
    Cool 5 series driveshafts. e28 and e34 & need e34 diff
    I have a driveshaft from a 1986 535 manual, and one from a 1990 535 auto. The 1986 has a new center support bearing and the one from the 1990 may need a new cv joint.
    I also need an e34 diff for my 535 the 3.91 makes first gear useless after the manual swap. If by some chance someone wants both of these driveshafts I'd trade for an e34 diff with a lower ratio open or lsd.
    Oct 2007
    atlanta, ga
    2010 528i and '86 640csi
    I have a 3.46 medium case diff from my '86 635 (150K or so). Open diff, new seals all around. I would let it go for $100 (local pickup - Atl). Normal wear, no issues. I went with even lower ratio with V8 transplant.
    Sep 2017
    Vienna, VA
    1995 525i E34 6-speed
    Quote Originally Posted by raydawg22 View Post
    I happen to have a 3.23 lsd that has the input and output flanges on it to bolt into a 535i/5 e34. I swapped a 3.46 lsd into my car and had to swap flanges between the two diffs. I have oil analysis records for the diff as well as dates and mileages of last fluid changes. It makes no sounds and locks pretty well.
    Aug 2017
    USA
    1990 BMW 535i
    [QUOTE=Singing6;30328722]I happen to have a 3.23 lsd that has the input and output flanges on it to bolt into a 535i/5 e34. I swapped a 3.46 lsd into my car and had to swap flanges between the two diffs. I have oil analysis records for the diff as well as dates and mileages of last fluid changes. It makes no sounds and locks pretty well.
    Super late reply but any chance you still have it available
  1. need e34 zf driveshaft
    By e34Mpower525i in forum 1988 - 1996 (E34)
    Last Post: 07-12-2012, 03:54 PM
  2. E34 92 525iT e34 Touring! Needs some love or parts car. $1200
    By e28Jay in forum 5 series & 6 series
    Last Post: 03-16-2011, 11:39 AM
  3. E34 Need e34 parts
    By shermanator15 in forum BMW Parts Wanted
    Last Post: 12-20-2010, 05:06 PM
  4. Need e34 driveshaft, fast.
    By jonky5 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 02-19-2009, 05:40 PM
