Results 1 to 4 of 4
Thread: Help! Bmw e36 overheating/thermostat issues/massive leaks
    Apr 2019
    Kelowna B.C, Canada
    1994 BMW 325is
    I have a 1994 325 iS that I just replaced a head on. I've done this many times - used new head bolts, new head gasket, copper gasket sealer, etc.
    Now that its all back together, my car is overheating while trying to refill and burp the coolant. I replaced the thermostat because it didn't seem to be opening, and it still wont open. It refuses to bring coolant from my Rad into the motor. Ive filled the resevoir up until is is full and cant take anymore and is going down the exces line, but both return hoses from rad to thermostat housing are dry and the housing is dry.....
    What is going on!!!
    Also will overfilling the resevoir cause the excess coolant to leak out???
    UGGHHHHHHHHHH
    Connecticut
    '98 ti (M powered)
    So, you tested the thermostat in a cup of hot water in the sink to verify it is opening properly at the right temperature? If not, that's step one.
    If it is, you have an air issue. Park the car so it is nose up- the steeper the grade the better. Fill as best you can and let it sit an hour, and then add more as it seeps in. Make sure the heater is on, "full blast" and keep adding coolant as the thermostat finally opens. Note that the thermostat WON'T open if it's not in water- if it's dry, due to some blockage, it will never open. But, you also should not be getting a water temperature reading without water, and the sensor and thermostat are in the same housing...
    I think even the crappy Haynes manuals detail burping the system. Since you are doing a head gasket, perhaps the radiator is blocked, which caused the overheat the first time... HAs all the support equipment been checked? The water pump impeller is turning correctly, and not spinning free on the drive shaft? (another common failure)
    "Speed's just a question of money. How fast you 'wanna go?"
    PM me for E36 engine swap books and BMW ETMs! NOW SHIPPING!!!
    MauiM3Mania's Avatar
    Jan 2002
    Central Pacific
    88M3 99M3 04M3 ITBx16
    OP, did you get this straightened out?
    88M3 AW 43k miles Project FS
    Jan 2016
    Ca
    2001 525it
    Jack up the front end when bleeding
  1. E36 NEW Genuine BMW E36 M3 Thermostat Housing
    By wrecklessauto in forum Drivetrain & Transmission Parts
    Last Post: 06-26-2012, 01:01 PM
  2. Help asap! Aux heater water pump massive leak need to bypass
    By darknezz7 in forum 1988 - 1996 (E34)
    Last Post: 04-15-2010, 09:43 PM
  3. Overheating... Thermostat issue?
    By Taimur in forum 1991 - 1999 (E36)
    Last Post: 04-20-2009, 07:44 PM
  4. Help! BMW E36 iPod/USB 12v hook up wires mix up? (PICTURES)
    By delmarco in forum 1991 - 1999 (E36)
    Last Post: 06-27-2008, 10:48 AM
  5. PLZ HELP......bmw e36 common window prob
    By bohemian in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-31-2005, 01:58 AM
