Results 1 to 5 of 5
Thread: 328i auto vert top problems
    May 2019
    Boston, MA
    1997 BMW 328iC
    Hey all, I'm new to these BimmerForums! I come from a background of Japcrap (namely Mazdas) and my '97 328iC is a whole new playground for me.
    So, the previous owner informed me that the convertible top motor got wet at some point and is fried, which is fine. Out of curiosity today, I tried to open up the top manually (by popping out the tab, getting a 4mm allen key, unlocking it manually and pulling it down. However, I ran into a small issue...My laziness brought me to use a power drill and plug in an allen socket to it to speed up the process of unlocking the top using the mechanism. Unfortunately for me, this caused the bolt to literally drill through the top of the motor. Can't fix it, it's no good.
    Now, I could probably get another one of these from a junkyard and put a new motor in there, but it seems expensive and it could just break again; I see a lot of people complaining about these breaking frequently. If possible, I'd like to convert my automatic top to a full manual, like with the twisting latch and all. It just seems like much less of a hassle and a lot less electrics to worry about. Could anyone direct me toward a thread or a video that might describe this well? I did some searching and couldn't find anything of relevance. I just don't know what parts I need to buy (if any), and what I have to do in order to convert it to manual top.
    Thanks for any help guys! Sorry for being a completely dumbfounded beginner, guess we all gotta start somewhere, huh?
    Link to my idiotically destroyed locking mechanism: https://imgur.com/LCfb9eA
    Dec 2013
    People's Republic of MD
    22 doors and 4 tops
    Top locking motors do not fail usually unless the person whips out the drill......
    You can convert the top to full manual. You will need the front manual locking system and then the rear locking tonneau system. I can supply you with a replacement locking motor or the front manual parts. I do not currently have the rear parts.
    If converting to manual you will also need to cut out the U shaped bracket on each side of the top frame. I can show you in detail with pics if needed.
    Jul 2018
    Miami Beach
    E36, 9-2x
    Quote Originally Posted by 66 6 View Post
    Would you be so kind to show us? Same exact thing happened to me last Wednesday. Recently posted about it asking for suggestions. I too would like to go full manual. My knowledge is too limited to continue trying to figure out the auto top.
    Dec 2013
    22 doors and 4 tops
    Quote Originally Posted by Ooghee View Post
    You replace the auto locking setup on the front of the top with the manual set up.
    You remove all the rear motors and add the manual specific cables and handle inside the car that locks and unlocks the tonneau.
    You cut off the 2 U shaped brackets in the top linkage to allow for full manual use.
    You buy a manual top headliner as now your full auto headliner will not fit at the front locking area.
    You get your ass out of the car to put the top up and down but it's allot less cussing and complaining about how your full auto top is FUBAR!
    Jul 2018
    Miami Beach
    E36, 9-2x
    Thank you for the input. Is there a step by step thread you can direct me to? Seems pretty straight forward but for example, I don’t know what you mean by the U shaped brackets that you say need to be cut out.
  1. WTB - E36 Fully Auto 'vert Top RIGHT Locking Mechanism
    By AthruC in forum BMW Parts Wanted
    Last Post: 08-11-2011, 11:02 AM
  2. Can you stand one more leaking vert top problem
    By Cremaster in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 05-09-2011, 07:51 PM
  3. 98 M3 Power Vert Top Problem
    By Ghost2821 in forum 1992 - 1999 M3 (E36)
    Last Post: 04-09-2011, 02:29 PM
  4. 318 vert top problem.Help!!
    By vadavert in forum Convertible Questions
    Last Post: 04-02-2007, 07:15 AM
  5. E30 vert top problems
    By BASSDISCO in forum 1983 - 1991 (E30)
    Last Post: 07-08-2006, 01:14 AM
