Results 1 to 10 of 10
Thread: Rear engine seal.
    Sep 2010
    Corpus Christi Texas USA
    850ci, M5, Alpina B7
    Rear engine seal.
    Anybody got a guess West Coast Inde repair cost 2003 530i auto?
    May 2018
    Austin, TX
    00 M5 | 03 540i | 94 NSX
    You could have called a few shops and gotten real quotes in the time you spent making this thread.
    Sep 2010
    Not really and I live in Mississippi and trying to help the daughter of a friend aboard a US Navy ship in the Persian Gulf. Sorry for the poor etiquette.
    Jan 2015
    Shreveport Louisiana
    cost for?
    Sep 2010
    Shop price to remove and replace. Fix the leak in other words.
    Missouri
    '02 540i/6
    Most indie shops here in SoCal charge about $125 an hour for labor. Not sure what the book time is on that, but hopefully that helps a little. A friend of mine in Escondido has a shop. If you're sure that's where the leak is coming from I can have him get a quote.
    2002 BMW Titanium Silver 540i/6-speed Sport - ZHP Shift Knob - M5 Clutch/TTV Racing 15.6lb Flywheel - M60 Intake Manifold - N62 84mm TB - Dinan Intake Tube - 4" MAF Tube - DUDMD Tune - Magnaflow Resonator - Eibach 18mm Rear Sway Bar - Powerflex Front Sway Bar Bushings - CDV Delete - UUC SS Brake Lines - Koni Yellow Shocks/Struts - Eibach Springs - Zionsville Radiator & FDM
    Oct 2017
    Beaverton, Oregon, USA
    2001 E39 540i A, 207 k
    Well, the rear main seal parts are not expensive (about $100), but the labor is pretty intensive and a pita if you are doing yourself. Factor in about 3 or 4 hours professional mechanic work.
    Frankly, if the leak is only a couple drops overnight, just live with it...!!
    Sep 2010
    Thanks from everyone. Car is in Sac. Apparently more than a few drops but I can pass this on to her I will stay over on the 8 or Alpina forum side now.
    Oregon
    '99 528i/5, '01 Boobaru
    Quote Originally Posted by rosakirk12 View Post
    Stating the obvious here and I understand you can't check the car in-person, but be sure that any leaking is absolutely from the RMS. It's rare for the RMS to leak on its own. A poor installation or certain symptoms like excess crankcase pressure I suppose could cause it to fail, but oil from some other typical sources of leaks (oil filter housing gasket, vanos line, valve cover gasket) has a way of collecting and dripping off, right down there at the bottom of the interface between the block and bell housing. Not a few techs have misdiagnosed that as an RMS leak. These other sources are far easier to deal with, thanks to being located on the top or side of the engine.
    Nov 2008
    M550iX, 540M-Sport, Scud
    Stuff happens. I had a rear main seal leak at around 90k miles. I think book time is around 8 hours. It will take an experienced tech around 5 hours to do the job...the exhaust comes off, the drive line disconnected, transmission removed, etc just to get to it. The swap of the seal is pretty quick...then back together.
    2001 540 M-Sport (cdn), ST X (KW) coilovers, H&R 15mm spacers, Eibach anti roll bars (28mm/18mm), Beastpower rear antiroll bar brackets, M5 rear chassis reinforcements (traction rods), Strong Strut front upper strut bar, Dinan Stage 1 software, factory M-Audio subs, Bavsound speaker upgrade, Bluebus bluetooth integration, Stop Tech SS brake lines, ATE coated brake rotors, ATE ceramic brake pads.
  1. 2002 525i rear engine seal replacement question
    By soth in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 12-11-2010, 02:54 PM
  2. Rear engine seal?
    By Nuckles in forum 1988 - 1996 (E34)
    Last Post: 03-08-2010, 10:55 PM
  3. Rear Engine Seal Quicky
    By Guild1974 in forum 1991 - 1999 (E36)
    Last Post: 11-20-2008, 09:30 AM
  4. rear engine seal
    By 320ipyro in forum 1975 - 1983 (E21)
    Last Post: 12-03-2006, 05:03 PM
  5. Can the rear engine seal leak oil or something?
    By NewToTheForum in forum 1991 - 1999 (E36)
    Last Post: 06-22-2005, 09:02 AM
