Results 1 to 7 of 7
Thread: enabling seat belt warning
    Jul 2017
    Turkey
    '00 540i M-Tech
    is there any way to enable (by coding) seat belt warning on e39? my seatbelt light just turns on and off for a brief moment when I switch the ignition on. I don't want it to turn off unless I fasten my seat belt.
    May 2010
    Allentown, PA
    1997 528 Auto 03/'96 M52
    Just making a guess here - and could be way off base, but... could a previous owner have bypassed the wires going to the latch? I'm probably oversimplifying here, but to better explain my point... If there are two wires going into the latch, that get 'connected together' when the seatbelt gets inserted, then maybe someone joined those two wires together to trick the computer into thinking the seatbelt is inserted. That way they could drive without a seatbelt on... remember... some previous owners are not that smart! I would imagine the initial idiot light you see is simply a 'test' of all the lights.
    Again, I could be wrong! Just throwing out an idea.
    Jaaap is offline ☀ ☁ ☂ ☃ ☏ ☠ ☢ ☣ ♕ ♫ ✂
    Jun 2008
    Belgium
    Alpina B10 e39 / F3
    I think it can be programmed with NCS Expert + Dummy in the KMB (Kombi / Pinnacle / Instrument Cluster).
    Look for they word "GURT".
    Jul 2017
    Turkey
    '00 540i M-Tech
    anyone else?
    can someone direct me on how to code it with ncs expert if it's possible?
    Oct 2017
    Beaverton, Oregon, USA
    2001 E39 540i A, 207 k
    Check out the BMW coding boards to learn how to code.
    See https://www.bimmerforums.com/forum/showthread.php?1800496-Dummies-Guide-to-Basic-coding-with-NCS-Expert
    Jul 2017
    Turkey
    '00 540i M-Tech
    I've seen that before but that doesn't specifically show seat belt warning.
    well, I need to figure it out myself I guess...
    Jun 2018
    Castle Rock CO
    1990 325is, 1998 740i
    its in the LCM coding or the SRS coding
    lcm does chimes SRS does some of the lights
    I like to pretend I know stuff
  1. Can I turn Off The Seat Belt Warning Tone?
    By luapninrud in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 08-19-2014, 03:08 PM
  2. seat belt warning chime
    By icheeban17 in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 01-05-2010, 09:44 PM
  3. 2005 Seat belt warning buzzer.
    By Alawrimore in forum 2002 - 2008 Z4 (E85, E86)
    Last Post: 07-02-2009, 10:06 PM
  4. Seat belt warning
    By Neetin in forum 2002 - 2008 (E65, E66)
    Last Post: 03-21-2009, 05:44 PM
  5. Seat belt warning fault?
    By trembler in forum 2002 - 2008 Z4 (E85, E86)
    Last Post: 10-29-2007, 05:58 AM
