Results 1 to 12 of 12
Thread: School me on roots style blower placement
    Apr 2017
    California
    1989 BMW 535i, 1993 740i
    I’ve seen it on m20s, sparse examples of it on m30s; I’m talking Eaton Superchargers bolted somewhere onto the motor, with the outlet pipe running to a FMIC, and then into the intake. I know that superchargers themselves are inefficient, compared to something like a turbo.
    However my question is, in a configuration where you are running that air from the supercharger, through all that pipe work and intercooler, are you losing power compared to having the supercharger mounted directly to the intake, like most OEMs situate it? From what I can tell that is more of an issue with packaging rather than maximum efficiency, and with an intercooler you obviously will be able to cool down that hot roots blower air. But does a roots blower make sense at all when you situate it far from the intake? Thanks for the help!
    O o
    ____________________________ ______________
    | BLAAAAAAAAAAAAAAAAAAAHHHHHHHH! !!!!
    \_ŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻ ŻŻŻŻŻŻŻŻŻŻŻŻŻŻ
    Apr 2006
    Minnesota eh?
    86 325es
    The dumpster, they should be placed in the dumpster.
    Apr 2017
    California
    What if I am a fan of the power curve, ease of install/removability, and don’t mind a little hot air and hp theft?
    O o
    Apr 2006
    Minnesota eh?
    86 325es
    then you should seek medical advice
    Apr 2017
    California
    I feel fine I swear....
    O o
    Apr 2006
    Minnesota eh?
    86 325es
    Jul 2005
    California
    Bima
    SW Florida
    99-01 M Cpe & Rdts, X5M
    Or, you could incorporate an air to water heat exchanger between the compressor and intake ports, connected to a front mounted radiator. Smaller diameter and easier to route piping runs, at the expense of running a circulation pump.
    Apr 2017
    California
    Quote Originally Posted by Randy Forbes View Post
    That sounds and looks like a pretty streamlined idea. Thanks for the insight, I’ll have to look into that as well if spacing/fab allows.
    O o
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Laminova cores and the custom work needed to fit will be expensive. Not sure how Eaton does it.
    Apr 2017
    California
    I assume all the added complexity and cost of a liquid intercooler sandwiched inbetween the SC outlet and intake manifold would be better suited to a twin screw setup?
    O o
    Bellingham, WA
    1998 M3, 2001 530i
    The issue I have run into in the past with a roots blower is fitting a large enough blower and charge piping under the hood to generate enough airflow to overcome the IC pressure drop and provide decent manifold boost pressure, while not spinning it so fast that it overheats, kills the bearings, and seizes the rotors to the case. Especially if the blower is sourced from a Mercedes C230 owner who couldn't be bothered to do any maintenance on it.
    My pockets have never been deep enough to mess with twin screws and water cooling. The Mazda Millenia OEM twin screw is cheap and would be interesting on a 2L engine, but it's like 26 inches long or something and won't fit in a small engine bay. Now if you had an I6 with enough room for two of those... you could have quadruple screws. Screw quadruplets? Heh, heh.
  1. roots style??
    By Kanufixit2 in forum Forced Induction
    Last Post: 03-20-2010, 04:14 AM
  2. E36 M3 with my touch of some old school E30 M3 style ...
    By Jeff M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 02-24-2005, 10:08 PM
  3. euro's and roots type blowers?
    By Transporter_E38 in forum Forced Induction
    Last Post: 04-21-2004, 08:10 PM
  4. Roots Blower For E36 under $2K
    By Bad Bimr in forum Forced Induction
    Last Post: 04-20-2004, 10:07 AM
  5. evolution/rally style schools?
    By NoSoup4U in forum Middle Atlantic - US
    Last Post: 10-07-2003, 02:28 PM
