Results 1 to 6 of 6
Thread: Replaced Fuel Pump- Do I need a New Filter?
    May 2019
    United States
    BMW
    So I recently picked up an 04 325i and while driving at a steady speed the car bogs down and died. I had to get the car towed and apparently the fuel pump just died on me while driving. https://solitaire.onl/ 9apps.ooo/ https://bluestacks.vip/ I ordered a new pump and replaced it and the car is now running again. Does the pump usually go because of increasing back pressure from the filter or does it kind of die after a certain amount of time regardless of the condition of the filter?
    From my experience, they just die with age. However, the fuel filter should be replaced as part of routine maintenance. If it's never been replaced before, then I would highly recommend doing it. Just don't mix up the lines. There's two on the back of the filter.
    MauiM3Mania's Avatar
    Jan 2002
    Central Pacific
    88M3 99M3 04M3 ITBx16
    Moved from the General BMW Discussion sub-forum.
    88M3 AW 43k miles Project FS
    Apr 2013
    Mill Valley, CA
    2003 330cic
    If the filter is over 60k miles old replace it. You can diagnose, but it is a good maintenance item.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Make sure you buy a fuel filter made by either Mahle or Keyser. Both supply filters to BMW. Do not buy a cheap aftermarket fuel filter as the fuel filter gas the fuel pressure regulator.
    Jan 2017
    USA
    E21, E46
    Definitely replace the filter.
  1. Just replaced Fuel Pump Relay and new one went bad the next day
    By eethirtyfour in forum 1988 - 1996 (E34)
    Last Post: 10-22-2010, 05:50 PM
  2. Total cost to replace FUEL PUMP
    By aaa1126 in forum 1991 - 1999 (E36)
    Last Post: 06-29-2006, 06:17 PM
  3. F/S fuel pump 325i 1989 e30 like new 150 can$
    By bmwQUEBEC in forum BMW Parts For Sale
    Last Post: 01-06-2006, 01:08 PM
  4. replacing fuel pump E28...???
    By SDSUe36 in forum 1988 - 1996 (E34)
    Last Post: 10-22-2005, 09:04 AM
  5. Help, replacing fuel pump!
    By fabby318 in forum 1988 - 1996 (E34)
    Last Post: 03-27-2005, 11:59 AM
