Results 1 to 4 of 4
Thread: 04 745i blue smoke - pcv valve
    Feb 2019
    ng9 uk
    04 745li e66
    Hi all i have a 04 plate 745i and its exhibiting PCV symptoms as in after long periods on tick over in traffic all of a sudden it will bellow blue smoke out the exhaust, which disappears once i get running again, i have removed and checked both PCV valves and they are undamaged, any help would be appreciated, although the valve seem undamaged could they be faulty, when running loosening the oil filler cap effects the idle and shows a very strong vacuum exactly how much vacuum should there be?
    MauiM3Mania's Avatar
    Jan 2002
    Central Pacific
    88M3 99M3 04M3 ITBx16
    Moved from the General BMW Discussion sub-forum, retitled.
    Hopefully you will get some help in this area of the forum.
    88M3 AW 43k miles Project FS
    You need valve stem seals. It's super common, try searching.
    Jan 2016
    Ca
    2001 525it
    Or try 10-60 m oil for awhile, but you have to drive it for while because there's oil on the cat, we have had good results with this
  1. 2005 745i no smoke no valve related symptoms but dealer says it needs a valve job.
    By Crothersins in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 08-22-2013, 12:26 PM
  2. 2005 740i smoking at idle - PCV Valve?
    By adhansen in forum 2002 - 2008 (E65, E66)
    Last Post: 01-02-2012, 10:17 PM
  3. 2005 740i smoking at idle - PCV Valve?
    By adhansen in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 12-12-2011, 12:40 AM
  4. Blue smoke from m20: valve seals or rings?
    By joey79 in forum 1975 - 1983 (E21)
    Last Post: 09-29-2011, 07:31 PM
  5. bad PCV valve = wight smoke...
    By DRIEV in forum 1992 - 1999 M3 (E36)
    Last Post: 03-23-2010, 11:52 PM
