Results 1 to 6 of 6
Thread: 520I I can't get the new water pump to stop leaking.
    Nov 2016
    Slovenia
    e39 520ia (year:1997)
    Hi guys, so I had a thread about changing the water pump on my BMW 520ia M52 this winter. I bought the Hepu pump as most of you recommended and it works as it should ,car runs cool with an exception that it still leaks. I think that it leaks a little bit only when the car sits for a long time and it's cold outside, i'll find a few drops beneath the car. It doesn't leak if the weather is warm.
    So i suspect the pump itself is OK and the problem is in main seal, a mounting surface or i didn't torque the pump correctly. I used the 89 inch pounds/10,1 NM of torque (using a cheap torque ratchet) . Is this correct?
    I also lubricated the rubber seal prior to the installation so it couldn't get damaged and i am fairly certain that i cleaned the mounting surface properly. But i did notice a tiny scratch on a "block adapter " mounting surface so this could maybe get the water past the seal when the seal gets cold and it shrinks.
    I think i have a solution for this. I am thinking of buying a temperature resistant silicone ,take the pump out and just make a thin layer over the outside pump's mounting surface around the screws etc. Do you think that's OK to do that? Or do you think i used insufficient torque?
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    I'd use this on both sides of the gasket.
    https://www.permatex.com/products/ga...licone-gasket/
    Nov 2016
    Slovenia
    Thanks for the link. I had something like this in mind. Gotta check if it's sold in EU. Do you mean to apply it on the inside rubber ring gasket or on the pump's mounting surface or both?
    JimLev's Avatar
    Sundance Mesa, NM
    Apply on both.
    Jan 2018
    Illinois
    1998 528i bmw
    Hopefully that solves your issue!
    Nov 2016
    Slovenia
    Quote Originally Posted by Young 23 View Post
    Yeah tnx,i hope so too, but i think it will since it's a minor leak. Those engines are great but they just love to leak. Well at least my coolant will be flushed this way without having to drain the block and hoses, bcs when i'll open it again i'll loose around 6 ltrs of coolant again.
  1. New water pump and still leaking
    By Chelseac.624 in forum 1999 - 2006 (E46)
    Last Post: 09-12-2016, 02:35 PM
  2. Best place to get new water pump?
    By ~vo328~ in forum 1991 - 1999 (E36)
    Last Post: 10-06-2004, 05:07 PM
  3. new water pump questions?
    By MMNJTWA in forum 1992 - 1999 M3 (E36)
    Last Post: 11-06-2003, 08:02 PM
  4. New water pump (plastic)
    By Canon in forum 1991 - 1999 (E36)
    Last Post: 11-04-2003, 07:12 PM
  5. new water pump, thermostat and housing in
    By nydog in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 05-15-2003, 12:58 AM
