Results 1 to 6 of 6
Thread: Tie rods seized together
    Nov 2017
    Canada
    1998 E36 328i
    Hello, today i went to change both my outer tie rod ends one side went well but the drivers did not. After much struggle i got the lock nut off but after i cant separate my outer from my inner tie rod. I have been spraying penetrating oil and loads of heat but i just cant get them separated, the flat spots on the inner are becoming round and im getting no closer to getting the outer off. Does anyone have any good ways to hold the inner to crack it loose? Or am i stuck waiting a week for a new inner to come in and just replace both?
    Oct 2003
    Seattle
    99 M3
    Yes you are stuck. They are not got to come apart. Replace both the inner and outer on both.
    Feb 2002
    Orlando, FL
    Turbo 97 E36 M3, 99 M3
    Get a pair of channel locks or remove it, put it in a vice, and see if that will work.
    1997 Arctic Silver/Black M3
    1999 Techno Violet/Dove M3
    Jan 2002
    outta SoCal, now CO
    '98 M3 Alpine White
    A quality tie rod end costs about $35 and the whole assembly is only $50 per side. Half that for the cheaper parts. Shouldn't have even been an issue, replace the whole assembly.
    See ya later,
    tony
    '98 M3, '92 Dinan3, '05 R1100S BCR, '07 R1200S, Aprilia T
    Oct 2003
    Seattle
    99 M3
    ^+1...disassemble and generously apply anti-seize to the threads.
    Nov 2017
    Canada
    1998 E36 328i
    I only ordered the outers and nowhere within 4 hours of where I live stocks any BMW parts so it wasn't as easy as just grabbing a new inner. What I ended up doing is cutting off the balljoint just short of where the inner tie rod ends then cut 4 slats going along what was left and hammered them off. I wire wheeled all the threads and the new one went on no problem and all my issues are gone.
  1. seized outer tie rods
    By Kody in forum 1991 - 1999 (E36)
    Last Post: 02-28-2013, 08:10 AM
  2. Brand new tie rod seized?
    By bzaster in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 07-08-2012, 11:41 PM
  3. seized outer tie rod
    By vishal25pm in forum Suspension Tech and Handling sponsored by eBMWParts.com
    Last Post: 04-15-2012, 06:41 PM
  4. Seized tie rods, what to do?
    By SleekBMW in forum 1996 - 2003 (E39)
    Last Post: 03-22-2008, 12:37 AM
  5. The brand new Meyle tie rod seized
    By archyx in forum 1991 - 1999 (E36)
    Last Post: 10-23-2006, 03:44 PM
