Results 1 to 4 of 4
Thread: High idle, Rpms slow to return to idle
    Apr 2019
    Charlotte nc
    E34
    I’ve got a 95 530 with a m60b40 out of a 94 540, got done doing some head work recently(replaced a burnt exhaust valve) and ever since it has idled at about 1000rpms. I suspected it was a vacuum leak so I hooked a smoke machine up to it and didn’t find any vacuum leaks, after that I decided to try and swap the iac from my 3.0 over to it to see if maybe I had a faulty iac, first startup with that iac it stumbled for a second but then went back to idle at about 600 where it was normally at before. Next morning I start it up to leave for work and it’s back idling at about 1000 again. Decided to see what it would do if I unplugged the iac and it goes down to idle at about 600 with it unplugged. To me it seams like it’s compensating for a load that isn’t there. Any one had a similar problem or might know where I should look next?
    Apr 2019
    Charlotte nc
    E34
    I keep posting on here and solving my own problems not even an hour later😂, but if anyone comes across this with the same problem my fix ended up being I had the secondary tps and the primary tps connectors flopped so the dme thought I was wot all the time🤦🏻*♂️
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    moved from 5 series general to E34 forum
    May 2017
    Australia
    1989 535i
    I had the same sort of issue last year. My idle would sit around 1100 rpm and it seemed the throttle on my M30 was sticking a little. A little lubing and it all returned to normal, sometimes the simplest fixes are the best fixes.
  1. Replies: 7
    Last Post: 06-03-2010, 02:57 AM
  2. 1987 325iC - Rythmic High/Low RPM at Idle
    By rmwill in forum 1983 - 1991 (E30)
    Last Post: 10-12-2008, 10:22 PM
  3. idle rpm high when warm
    By talisman in forum 1991 - 1999 (E36)
    Last Post: 09-13-2006, 07:45 AM
  4. E36 RPM slow to return to idle
    By housinit in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 03-15-2005, 02:20 PM
  5. Help Please!! high idle rpm, ASC on, stay high gear
    By myspenser in forum 1995 - 2001 (E38)
    Last Post: 11-15-2004, 10:35 PM
