Results 1 to 3 of 3
Thread: 03 Z4 Radio issues
    Jun 2018
    NB Canada
    2011 550i xDrive M Sport
    03 Z4 Radio issues
    The business unit stereo when switched on POPS off. Then comes back on again and POPS off again. When I purchased the car the fuses were removed. Unable to contact previous keeper to ask why. I replaced the 7.5 and 30 fuses and when it POPs off the fuses do not blow. Any ideas??
    Oct 2012
    Victoria BC Canada
    2004 Z4, 1700 Nomad MC
    Are you saying the radio comes on then switches off then switches on then finally switches off....
    I would first check the amp in the battery well.... it’s possible that the amp is potentially water damaged leading the radio to attempt to switch the amp on and finally switching off when it won’t. Check for water marks on the amp.
    I’ve an ‘04 so am familiar with the placement of the amp. Any water ingress to the trunk...spilled water etc will eventually find its way to the battery well. I drilled a small hole through the plastic under the amp to ensure anything spilled/leaked doesn’t pool...
    Depending on whether you have the high end Carver 10 speaker unit or not... there are two versions of amp... expensive and insanely expensive. I have the high end DSP Amp which was about $1200 CDN new with taxes. The “normal” amp is half that price.
    You can check with eBay etc for availability but hifi DSP amp is likely not available. See below for how to get part number for replacement amps...
    You should check your VIN with a VIN decoder to see what your car is equipped with...
    https://bimmercat.com/bmw/EN/vin/decoder/online (last 7 digits)
    Check on realoem.com or BMW fans.info with same 7 digits to see part number of head unit /amp compatible replacements.
    Head unit on non DSP systems can be replaced with non BMW radio ... HiFi DSP (Carver 10 speaker system) can’t be replaced with non BMW radio... Lots of posts on this. Google is your friend here...
    Hope this helps with trying to isolate your issue.
    Jun 2018
    NB Canada
    I will take a look at the amp. Strange, the noise it makes sounds horibble (pop)I would sooner listen to the engine anyway but.....
  1. 1st time '03 Z4 owner with various (and possibly related) issues looking for advice
    By immoralimmortal in forum 2002 - 2008 Z4 (E85, E86)
    Last Post: 05-15-2019, 10:12 AM
  2. BMW Z4 03 Door lock issues
    By poonkoons in forum 2002 - 2008 Z4 (E85, E86)
    Last Post: 01-11-2017, 03:17 PM
  3. 03 Z4 battery issue
    By simonskl0808 in forum 2002 - 2008 Z4 (E85, E86)
    Last Post: 06-08-2016, 08:41 PM
  4. 03 Z4 AM/FM radio stopped working, CD works fine
    By geftman in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 07-31-2011, 10:13 AM
  5. Z4 E85,E86 NEED: Driver side headlight 03 z4.
    By djervin in forum BMW Parts Wanted
    Last Post: 04-05-2010, 09:46 AM
