Results 1 to 8 of 8
Thread: Did I get a bad fan switch?
    Feb 2019
    Cleveland Tennessee
    1998 BMW Z3 2.8
    I have a 98 Z3 2.8 I was in city traffic and notice my temps starting to climb. I stopped let it cool down. Moving down the interstate temps were steady at 12 o'clock on the gauge. I replaced the fan switch and the fan still doesn't come on. I bled the air and filled the reservoir.
    LOW SPEED fan comes on with switch on and A/C on
    LOW SPEED fan comes on when using a jumper
    HIGH SPEED fan comes on when when using a jumper
    so low and high speeds on fan work
    I pulled the relays checking for corrosion they looked good but cleaned anyways.
    With any one of the relays removed (high speed, low speed or AC compressor) the low speed fan would not work with the AC turned on.
    Once all relays plugged in low speed fan works with AC on
    Does this mean my relays are all good?
    Am I missing something or did I get a bad switch?
    Dec 2007
    Great Dismal Swamp
    E36/7 E36/8x2 E46 F25
    You are most likely missing something. The fan switch doesn't care a bit about engine temp.
    /.randy
    Nov 2018
    Truckee, CA
    1997 Z3 Roadster 1.9L
    I can't find the link, but I remember a couple of discussion threads about a brown wire leading to the fan or a temperature sensor that was incorrectly wired at the factory.
    Your symptoms might be related to that.
    Feb 2012
    MN
    1997 z3 roadster
    It's a Hybrid--Burns Gas and Rubber
    May 2012
    USA
    2000 BMW Z3 2.3 Auto
    The mechanical fan works fine? Not slipping right?
    My car have a sensor screwed to the radiator. This one also controls the high / low speed of the fan. Long time back, to test it, i used a candle or some heat source to heat it and it set the fan running at high speed. I rarely see it running at high speed. Even with AC on at Texas weather.
    Low speed fan, on with AC On, it should go on. Also controlled by the DME. High speed, i think AC pressure also turns it on other than the sensor on radiator.
    Mesa, Arizona
    2000 Z3 M-Roadster
    There's so much information on how the aux fan works on this site.
    A little search...
    https://www.bimmerforums.com/forum/s...aux-engine-fan
    Tony
    "You can't sign away negligence."
    Sep 2019
    India
    BMW
    Depending on the test light you have, the yellow/green will test as 12V+ when "ECTS" is off, [coolant below 194F] if tested at the switch or at the relay and as a ground when "ECTS" is on, [assuming it works].
    With that said, the problem with a test light is it can supply the low current ground the relay needs to energize, [turn it on], which in turn will, [should] turn on the rad fan.
    Grounding the yellow/green at the "ECTS" is a good way to test the rest of the rad fan circuit, turn ign. switch on then ground the yellow/green, rad fan should turn on, no matter what the engine temp.
    I would use a stock "ECTS" although 180 degrees F would probably also be OK, the stock switch is "around" 194 F. My car have a sensor screwed to the radiator. This one also controls the high / low speed of the fan.
    nissan kicks price
    I would suspect a bleeding issue or a thermostat issue or something personally
    PRICE CUT on ALL FABRICS
  1. Do i have a bad fan or a bad fan switch?
    By platinumfossil in forum 1999 - 2006 (E46)
    Last Post: 08-21-2009, 01:59 PM
  2. 95 E36 M3 overheating ? bad fan switch?
    By ///MD in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 09-26-2006, 08:44 AM
  3. aux fan only turns on when AC is on. bad fan switch?
    By hc1001 in forum 1992 - 1999 M3 (E36)
    Last Post: 07-18-2006, 11:20 PM
  4. AUXILARY FAN; is the resistor bad or the fan switch?
    By mimikr in forum 1982 - 1988 (E28)
    Last Post: 04-07-2003, 07:23 AM
