Results 1 to 6 of 6
Thread: E36 M3 squeal - please help
    May 2019
    Jersey City, NJ, USA
    1997 BMW M3 Coupe
    Hi,
    First post. When pressing throttle, get this squealing. Have a theory, but curious if anyone recognizes the cause and can point me in right direction. Would like to fix this myself.
    Thanks in advance
    RRSperry's Avatar
    RRSperry is offline Mostly Senior Member BMW E36 M3 Expert
    Mar 2002
    Eldersburg, Md
    95 ///M3sc, 16 C7 Z51
    Idler pulley or belt tensioner. Possibly the alternator.
    Oct 2003
    Seattle
    99 M3
    Or belt, due to a dirty/failing tensioner/tensiorer pivot.
    Remove the belt, remove test the tensioner pulley and idler pulley, they should be smooth and quiet and should stop rotating quickly due to internal lubricant and seal stiction.
    Take the tensioner off and apart, lube the pivot shaft and bearings and reassemble and reinstall.
    Often, you can use a Mechanic’s Stethoscope to located the errant part, or if no one part stands out, it is the belt and a ‘lazy’ tensioner that is the cause.
    https://www.homedepot.com/p/Lisle-Me...2500/306763901
    FL
    are slow.
    Quote Originally Posted by RRSperry View Post
    This.
    Pop the plastic cover off the tensioner, use 8mm allen bit (or 10mm, I forget) on a break bar on the belt tensioner (through it), turn it counter clockwise. Take the belt off the alternator, and you can then spin each by hand and find out which one is squealing.
    https://www.autozone.com/repairguide...00c152801b22fb
    I usually just re-pack my idler pulley and belt tensioner with grease whenever I take the belt off, or every few years. They have worked flawlessly for 10+ years.
    -Dr. Seuss
    NeilM is offline Member BMW E36 M3 Expert
    Fort Wayne, IN
    96 M3, 15 Golf R, 18 Q5
    This
    There's a distinct metallic tone to the sound, so not likely to be the belt.
    Neil
    May 2019
    1997 BMW M3 Coupe
    Thanks for all the replies.
    It's likely the alternator (maybe bearings or pulley?) as it started after recent replacement. My mistake for getting one off ebay. Was only thing replaced.
  1. 95 e36 m3 midpipe upgrade help please!
    By bondovw in forum 1992 - 1999 M3 (E36)
    Last Post: 08-31-2010, 04:35 PM
  2. UGH- E36 M3 Radio headache- HELP ME PLEASE
    By bmwaddicted49 in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 01-18-2008, 05:01 PM
  3. NTB!!! Anyone with E36 M3 parts please help!
    By m3pastu in forum BMW Parts Wanted sponsored by Bavarian Auto Recycling
    Last Post: 02-09-2005, 06:20 PM
  4. Couple of E36 M3 problems...please help...
    By joeyc in forum 1992 - 1999 M3 (E36)
    Last Post: 03-31-2004, 04:20 AM
  5. Need pictures of modded E36 M3's, folks! Help, please :)
    By Micah D. Cranman in forum BMW Rides & Events
    Last Post: 02-12-2003, 06:51 PM
